225?235?
Old Dec 4, 2009 | 09:28 PM
Dr. klein's Avatar
Dr. klein
225?235?
hi there!!
would you please let me know about the rubbing issue?
I have plan to set wheel and tire set for my mini R57
-also to set H&R lowering spring
1. volk RE30 7.5J 17 ET 48 with 235/40/17
2. neez 7.5J 17 ET 43 with 235/40/17
3. challenge spoke 7J 17 ET 48 with 225/45/17
With above setting, is there any rubbing?
Old Dec 5, 2009 | 02:43 AM
howsoonisnow1985's Avatar
howsoonisnow1985
2nd Gen
I'd go with 235/40/17 ala MachV Dan
Although, this offset on theez Neez 7.5J 17 ET 43 with 235/40/17 might be have fender rub as Lil Rose mentioned. ET48s gives you opportunity to play with spacers in case you might need 3mm or 5mm spacers for trailing arm or big brake kit.
Old Dec 5, 2009 | 06:05 AM
Lil Blue Coop/Mini Rose's Avatar
I am running 225x45x17 on ARA AR2's 17x7 et 42 with BC coilovers and only have rubbing issues on large dips. The tire rubs on the plastic lip. I do run with just a little over a fingers gap between the tires and plastic lip so that contributes to the rubbing.
donniedarko
Oct 21, 2015 01:15 PM
TOMSR53
Aug 26, 2015 10:18 AM
blackie
Aug 25, 2015 09:08 PM
tylewis
Aug 18, 2015 06:53 AM
kwijmbo
Aug 5, 2015 09:00 PM
