Just bought a set of Michelin Primacy Alpin PA3 ZP Tires, but no RSC in a Circle?
Old Dec 4, 2009 | 08:47 AM
KalJer's Avatar
KalJer
Hi guys,
I just picked up a set of Michelin Primacy Alpin PA3 ZP (Zero Pressure) tires for my MCS this winter. I mounted them to the car and then while checking for the correct torque specs I came accross the section of the manual that says to only use runflat tires as designated by RSC in a circle stamped on the sidewall. I know RSC stands for runflat system component, but don't understand why these ZP (zero pressure) runflat tires don't have the RSC?
Should I be concerned?
Thanks!
Old Dec 4, 2009 | 09:16 AM
ronnie948's Avatar
ronnie948
I would not woory at all.
I would be certain that the Michelin tires are marked ZP. (RSC) is just a designation for the tire being a run-flat. Go out and look at those tires and be certain they have the "ZP" printed on the sidewall. If so just keep on truckin.
I'm hoping you got them for all four wheels as advised by Michelin. It actually says they are not to be mixed with other tires.
Last edited by ronnie948; Dec 4, 2009 at 09:23 AM. Reason: Add info and of course spelling again."worry not woory"
Old Dec 4, 2009 | 10:14 AM
Alex@tirerack's Avatar
Alex@tirerack
As Ronnie stated, Zp = no problems!
Alex
Old Dec 4, 2009 | 10:47 AM
KalJer's Avatar
KalJer
Thanks for he replies! So is RSC not a universal, required, runflat tire designation? If so, why does the Mini manual mandate that designation?
Thanks!
Old Dec 4, 2009 | 10:57 AM
COR BLMY's Avatar
COR BLMY
because MINI is not "in bed" with every tire mfg
FLYM1N1
Oct 13, 2015 04:33 PM
minipopkart
Aug 13, 2015 05:22 AM
cjsdad
Aug 11, 2015 08:46 AM
nomar116
Aug 10, 2015 11:24 PM
nomar116
Aug 9, 2015 09:42 AM
