Carbotech pads lack bite?
Old May 22, 2009 | 07:23 AM
  #26
n733lk's Avatar
n733lk
Recommendations
Originally Posted by AutoXCooper.com
Note the switch from XP8 to XP10 in the rears is due to change from street tires to R-comps. If you are stepping up to R-comps you may also need to step up on the pads. If you are not sure just send me a PM.
Dustin,
I'm a newbie at all this hands on stuff, but my Mini is bringing it out in me!
I'd like new brake pads becuase of the dust! Don't plan any race days, but drive somewhat average to spirited. Which pads would you recommend? Are they easy to replace myself?
Thanks!
Old May 22, 2009 | 08:14 AM
  #27
BlimeyCabrio's Avatar
BlimeyCabrio
I'm not Dustin, but I play him on TV - and he'll say "CarboTech Bobcats"
Here's my writeup on the Bobcats vs. the AX6 pads:
https://www.northamericanmotoring.co...34-post15.html
Easy DIY project, but does require a little time and know-how and a few tools. See the how-to's here:
Front
https://www.northamericanmotoring.co...tml#post550348
Rear
https://www.northamericanmotoring.co...beginners.html
Old May 22, 2009 | 08:46 AM
  #28
n733lk's Avatar
n733lk
Front
Rear
Thanks! As for your comment above, it's the "know-how" part that worries me.
Old May 22, 2009 | 08:50 AM
  #29
BlimeyCabrio
We all have a "first time"... no worries - just read the DIY's first - if it sounds like something you can handle - then you can - it's not that hard.
Old May 22, 2009 | 09:04 AM
  #30
n733lk's Avatar
n733lk
What's the worse that could happen . . . I run into a tree
Old May 22, 2009 | 10:00 AM
  #31
AutoXCooper.com's Avatar
AutoXCooper.com
Paul's right, he likes it when I say that out loud , and the Carbotech 1521 aka Bobcats are a great pad for you. You may also need rotors if you have more then 40K on the current set.
Old May 22, 2009 | 04:30 PM
  #32
Some Guy's Avatar
Some Guy
If you are just doing pads it is a piece of cake, there is very little that you can mess up if you follow the DIY's.
Old May 22, 2009 | 06:27 PM
  #33
Sin MINI's Avatar
Sin MINI
Originally Posted by Some Guy
The opposite. If your pads arent capable of triggering the ABS then your car isnt coming to a stop as fast as it is actually able to. Basically the pads are too weak.
That's what I meant...
Old May 23, 2009 | 07:13 AM
  #34
n733lk's Avatar
n733lk
Silly question here gang . . .
Can I just change out the front pads or do I need to change out front and rear?
Old May 23, 2009 | 07:15 AM
  #35
cct1's Avatar
cct1
Depends on what you do with your car, and what your goals are, but the answer is yes you CAN. Wether you SHOULD will depend on what you're after....
minimofo
Sep 20, 2015 05:17 PM
Colt45Magnus
Sep 16, 2015 11:15 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Sep 4, 2015 09:23 AM
