Does anyone NOT rotate their tires...?
Old Sep 3, 2008 | 11:52 AM
  #26
OctaneGuy's Avatar
OctaneGuy
I drive a lot of miles---5,000 miles a month. I've been through a lot of tires. My Falken Ziex 512's were inexpensive tires--but didn't last long. My front's always worn down faster. Buying tires in sets of 4 are cheaper than sets of 2's. Even if you only plan to replace two at a time, it's better to buy 4 and have 2 extras for the next change.
Before my current setup, I rotated my tires because my fronts wore out so fast. Course autocrossing every couple of months didn't help the wear at all, lol.
My current tires are Nitto Neo Gens and I've put 25,000 miles on them, and wear has been even all the way around.
What's changed are the adjustable camber plates (Cross Coilovers) and an alignment (I have adjustable endlinks all the way around). Before that, I was going through tires much too fast. It's pretty cool to be getting decent tire wear on these tires--I'll definitely be getting another set to replace them!
Richard
Old Sep 3, 2008 | 12:07 PM
  #27
mellowmcs's Avatar
mellowmcs
Originally Posted by pilotart
Would there be an advantage for replacing four tires over the two you would buy if you did not rotate?
Was in Costco the other day and the gentleman in front of me was getting two tires; he wanted them mounted on front but Costco told him "Costco Policy was to place the 'best' tires on the rear".
Believe he drove RWD, but would this be true on FWD as well?
If this were the case, you would get a rotation at (two) tire purchase, by installing on rear and moving existing rears to the front.
also applies to FWD. reason being that a bald rear tire will cause the car to over steer vs a bald front tires that will cause the car to under steer. most people can control under steer better than over steer. most people will jump off the gas or hit the brakes in an over steer situation which is the wrong thing to do 99% of the time.
Old Sep 3, 2008 | 12:14 PM
  #28
nicknbecka's Avatar
nicknbecka
I'm at 40k on the original run flats (Bridgestone, IIRC) and haven't rotated tires yet. The fronts are definitely seeing more wear than the rear, but it's been pretty even across the tires.
Old Sep 3, 2008 | 01:00 PM
  #29
got.pho?'s Avatar
got.pho?
my front tires were super bald when I rotated mine, stupid hard corners =]
Old Sep 3, 2008 | 04:19 PM
  #30
gjhsu's Avatar
gjhsu
I should rotate them more than I do, but maybe now that I'm finally getting my own, sizable garage, I can be bothered to do it!
Old Sep 3, 2008 | 05:20 PM
  #31
gaston's Avatar
gaston
I never rotate tires. I replace the fronts about every 9-10k miles, putting new ones on back, old ones front. Not that I recommend this strategy, I just don't want to bother with rotation.
At the moment I want to get rid of the fronts. I prefer the original Dunlop RFs (back) to Conti RFs (front). I suspect what I learned is not to mix tire models when you have DSC. Which is an argument for rotation :-)
Old Sep 3, 2008 | 05:30 PM
  #32
MINIclo's Avatar
MINIclo
7th Gear Gal
I rotate my 2003 MCS's tires every 5-7K miles, have almost 80K miles on the odo, and am on the third set of runflats. Yeah, I'm one of the few who love the runflats, but that's because I do a lot of solo trips across the country and feel safer running them.
Old Sep 3, 2008 | 07:03 PM
  #33
JCR1960's Avatar
JCR1960
My tires always rotate when I drive they rotate around.
All kidding aside normally I rotate my tires at 5000 miles but I am waiting to do that until I hear from my SA to meet with the factory rep about the continued heat issue in the passenger footwell after the service bulletin was performed.
Old Sep 3, 2008 | 07:14 PM
  #34
orangecrush's Avatar
orangecrush
I have to agree. I think every car I've ever owned that came with runflats all received the same thing within the first week I owned them.... That being, new non-runflats.
However, I purposely haven't replaced the tires on my '08 with non-runflats because I tend to make a fair amount of long distance trips.
I figure the runflats may not be as good but they make me feel better on the highway. (not to mention they take a trashing on the track)
Mark
Old Sep 3, 2008 | 07:18 PM
  #35
rrcaniglia's Avatar
rrcaniglia
Originally Posted by minimalistic
I got a question, without a spare, how would a backyard mechanic rotate the tires?
Shade tree. Rope. Come-along.
Old Sep 3, 2008 | 07:31 PM
  #36
BlueBonnet's Avatar
BlueBonnet
I believe that having the best tread on the rear is good if you are planning to text message while driving. Otherwise, since the front wheels steer and pull, better tread there gives you a car with more capability . . . you'll get oversteer only in rare conditions, such as hard cornering during a tropical storm (which you may not notice if you are text messaging while driving). Of course, I avoid the problem by rotating my tires every 5000 miles, or whenever they are off for other reasons. The tread on my rear tires is less than that on the front for 2500 miles, and more than on the front for 2500 miles . . . .
Old Sep 3, 2008 | 10:32 PM
  #37
MPowerF1's Avatar
MPowerF1
With my tires, I am rotating every 3,000 miles to make sure they wear as evenly as possible. I purchased the tires at America's Tire which provides free rotations for the life of the tires. I highly recommend this as rotating the tires is the only way to get the most sustained performance out of the tires (and when all you have to do is drop the car off for 15 minutes, who cares...).
Old Sep 4, 2008 | 08:02 AM
  #38
Bigshot's Avatar
Bigshot
Originally Posted by OldRick
I'm surprised that anyone rotates MINI tires. My front tires wear out about four-five times faster than the rears, and with my summer tires that means about 8K miles for the front tires.
I can't see much point in rotating when the front ones wear out almost as fast as the rotation interval, and not rotating means that the rear tires are usually in better shape than the fronts. Also, this way I only need to replace two at a time, instead of four.
Sounds like you have more of a driving problem then tire problem. You shouldn't be going through tires that fast if you are a smooth driver. Have you taken any drivers training or track days with an instructor?
Or maybe you need some suspension work, like camber plates. They will aid in getting the car to rotate and take a lot of the wear and tear off of the front tires allowing the rears to do more work.
Old Sep 4, 2008 | 10:27 AM
  #39
Gil-galad's Avatar
Gil-galad
I guess that's okay if you're confident in their competence, you know it's the same tech or techs doing the rotation each time, and you trust them to care enough to treat your wheels with TLC and get the torque right every time. Seems like the uber-frequent, sight-unseen rotations unnecessarily increases the risk of an under- or over-torque of a lug bolt somewhere along the line.
I'll bet when your vendor offered free rotations they weren't anticipating that you'd be showing up on their doorstep every 3K.
Old Sep 4, 2008 | 04:30 PM
  #40
pilotart's Avatar
pilotart
Over/under inflation can cause odd wear pattern (center or edges) and alignment problems can really eat the tires.
Now we have to align the rear as well as the front ends.
Old Sep 4, 2008 | 04:54 PM
  #41
orangecrush
$5 jackstand?
Old Sep 4, 2008 | 05:04 PM
  #42
rrcaniglia's Avatar
rrcaniglia
Oh. They said 'backyard', not 'shade tree'. My bad.
Old Sep 4, 2008 | 06:25 PM
  #43
orangecrush
I didn't know there was a difference...
I figure in each backyard, there's a shade tree.
Mark
Old Sep 5, 2008 | 09:06 AM
  #44
agranger's Avatar
agranger
Originally Posted by orangecrush
$5 jackstand?
Or a hastily tacked-together stack of scrap 2x4s, for the junk-pile mechanic.
Old Sep 5, 2008 | 09:34 AM
  #45
Toeoutperformance.com's Avatar
Another reason for rotating vs. not rotating is so you will buy a set of 4 tires at the same time. This way you have a matching set instead of possibly having different brands front and rear since different tires have different grip levels and differing wet weather traction. Doing this just takes one more variable out of the equation. Also, sometimes tires get discontinued and aren't able to find 2 tires to match your old ones even if you try.
Old Sep 5, 2008 | 09:26 PM
  #46
MPowerF1's Avatar
MPowerF1
I'm sure they didn't. But that's what it takes to ensure that the car's balance does not get as compromised as it would if they were left alone.
Old Sep 6, 2008 | 04:27 AM
  #47
orangecrush
That's a very good point. One of my shops does almost all the Acura bodywork in town....point is, most of the cars we work on are 2006 and up.
Many, many times we'll have to replace a tire from an accident and it's discontinued. You'd think that they wouldn't change tires so fast considering that a manufacturer buys the exact same size and brand for a particular model.
Tire manufacturers remind me of computer companies, they're always upgrading their version...
Old Sep 6, 2008 | 05:30 AM
  #48
danielo's Avatar
danielo
Do we need an alighment when we rotate tires on a FWD car?
Old Sep 6, 2008 | 09:36 AM
  #49
Alex@tirerack's Avatar
Alex@tirerack
I'd check alignment prior to each set of tires, unless somthing had taken the car out of alignment prematurley - usually impact.
Alex
Old Sep 6, 2008 | 12:16 PM
  #50
orangecrush
Alex
I'm with Alex on that too.... unless there is something visually out of the ordinary, I wouldn't do an alignment.
However, if I put on a new set of tires, it's worth 45 bucks to me to ensure I'm not starting a brand new set of tires off in a bad wear pattern.
Mark
GAT
Oct 21, 2015 02:12 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Norton70
Sep 24, 2015 06:31 AM
rrglo
Sep 22, 2015 10:05 PM
minimofo
Sep 20, 2015 05:17 PM
