Ditching the run-flats?
Old May 31, 2008 | 01:12 PM
enricosonic's Avatar
enricosonic
Just perusing the forum's various threads and I see many have done this. I'm ready to ditch mine if there's a substantial difference in ride quality. The run-flats are all I've known so I'm guessing I'd definitely feel a change for the better. I suppose a regular performance tire will be quite a bit cheaper too.
So... what if you get a flat? Unlikely I reckon but still - I'd rather not have the wife and baby alone somewhere with a puncture.
One other thing: anyone running 215s instead of 205s?
Old May 31, 2008 | 01:19 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Search for "non runflat" or 205/45-17, or 215/45-17. Both sizes easily fit a stock MINI with stock suspension.
Performance and comfort will likely improve, cost will be lower, tread wear can be increased.
If flat tire then call roadside assistance or AAA if you have a membership.
Or keep a compact spare tire in the boot covered with a tire bag.
Check out Ultra High Performance Summer tires if you have mild weather and UHP All Season tires if you have cold weather and some snow and don't want to change to winter tires.
Old May 31, 2008 | 01:31 PM
-Nathan's Avatar
-Nathan
I saw a huge improvement in both ride comfort and traction when I switched from Dunlop all-season DSST run-flats to Continental Contisport Contact 2's. I just keep my cellphone and AAA card with me. If you are concerned about being stranded with a punctured tire you might be interested in Continental's ContiComfortKit http://www.tirerack.com/accessories/...tkit/index.jsp
Old May 31, 2008 | 01:36 PM
enricosonic
Thanks, you guys. Good info. I don't think there'll be any more run-flats for me. That opens up a new world of options too.
Old May 31, 2008 | 01:52 PM
CFMINI's Avatar
CFMINI
You can also get a nice little compressor/flat fix kit from Mini or elsewhere to keep in the boot. It is a nice back up and the minimal risk is more than offset by the added ride comfort, performance and lower cost of run flats.
Old May 31, 2008 | 02:17 PM
wilhelmh's Avatar
wilhelmh
My Recommendation...
I'd recommend Continental ContiExtreme Contact tires in 215/45/17. They are Ultra-High Performance All-Seasons and will fit on the OEM S-Lites without any problem. I replaced my Goodyear run-flats and noticed a clear improvement. They are quieter, have much better grip and treadlife, last longer, and provide a more comfortable ride. The extra cushioning of the softer sidewalls will also protect your wheels from pothole damage (that's what motivated me to make the change--the hard way).
Oh, they are also considerably less expensive than run-flats.
For safety/convenience, buy a can of Fix-A-Flat at Target. Craftsman makes a nice portable air compressor for your trunk. With these, you won' have to worry about leaks or flats!
Make the switch. You'll be glad you did!
Old May 31, 2008 | 03:30 PM
enricosonic
khumpert
Nov 30, 2015 11:48 AM
ltjpunk7
Sep 6, 2015 07:32 AM
tontobird
Tires, Wheels, & Brakes
Sep 5, 2003 09:30 AM
Ken&MINI.com
68
Jun 8, 2003 10:35 AM
