Embarrassingly dumb question
Old May 6, 2008 | 10:05 PM
scruffylooking's Avatar
scruffylooking
Do run-flat tire work on any standard rim or do they require special rims? Sorry for the blatant n00bness.
Old May 6, 2008 | 10:13 PM
ubdylan's Avatar
ubdylan
no diff
Old May 6, 2008 | 10:14 PM
ubdylan's Avatar
ubdylan
...although the equipment for the mounting needs to comply.
Old May 6, 2008 | 10:28 PM
Guest's Avatar
Guest
Originally Posted by ubdylan
no diff
Not entirely true. Many of the stock Rim's have lips inside the rim to help keep the tire on the car during a total pressure loss situation. That being said, I'm not sure that it's entirely necessary.
Old May 7, 2008 | 06:10 AM
RedSkunk's Avatar
RedSkunk
Werd. I've heard of some (lame) tire shops giving people a hard time about installing runflats on aftermarket wheels, or vice versa. But from what I've read, the bead inside the wheel isn't necessary. (Maybe... if you're running no air at all in the runflat.. But despite their name, I've certainly had a flat with one before and wouldn't recommend no air, bead or no bead...)
Old May 7, 2008 | 06:59 AM
quikmni's Avatar
quikmni
I think the confusion comes from the original Michelin runflats of many years ago that did require a special wheel. You can definitely install a non-runflat on any of the stock Mini wheels.
Old May 7, 2008 | 09:15 AM
scruffylooking
Thanks people.
Old May 7, 2008 | 10:55 AM
dtm's Avatar
dtm
If you are having runflats installed on aftermarket rims (or any rims for that matter) make sure you take them to a REPUTABLE shop or risk damage to your rims . . . I would even go as far as to photograph rims before you drop them off. The runflats are nasty to install / remove.
Old May 7, 2008 | 12:21 PM
scruffylooking
Jeez. Who knew runflats would be a whole new world of tiredom. Thanks all for the responses.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
Panik
Sep 9, 2015 08:36 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
