Help finding correct paint to refinish silver OEM R84s
Due to the brake dust tearing up my rims I would like to refinish them. Does anyone know of a source for a silver paint that will match the original center caps? Or should I: A) paint them too or B) not worry about it?
The reason I ask is because I picked up some silver wheel paint to redo a
set of steel rims I had. The silver was VERY bright and metallic, nothing like the MINI rim.
I am going to go checkout Eastwood, but any ideas are welcome!
thanks!
-Jac
thanks!
-Jac
All paint codes
EASTWOOD is good, I get a lot of stuff there - but not for paint
here's all the paint codes 02 - 08 as pulled from the Sherwin-Automotive site
http://www.sunshineminis.org/forums/...ic.php?t=16182
(some one thought this was useful enuf to sticky)
With that code you can go to any decent automotive paint supplier locally
or if you want a rattle can off the web I've had good luck with
http://www.automotivetouchup.com/auto_paint.asp
blackie
Oct 2, 2015 07:41 PM
O4mcs
Aug 6, 2015 05:42 AM
