Drilled/Slotted Rotors for a Clubman?
Old Apr 8, 2008 | 05:57 PM
RaceFace's Avatar
RaceFace
I am going to replace the brake pads on my Clubman with organic pads. I am OVER the brake dust issue....and the car is only 3 weeks old. I've already found a company for the pads and I'm thinking of pulling the rotors too and replacing them with cross-drilled rotors while I've got the wheels and calipers off. Any one know who makes these rotors for a Clubman?
Thanks!!
Old Apr 8, 2008 | 06:20 PM
hemiheaded18's Avatar
hemiheaded18
Don't know about rotors but I thought my car had organics from the factory...
Old Apr 8, 2008 | 06:49 PM
RaceFace's Avatar
RaceFace
DUH!!! I guess thats what happens when I try to cook dinner for the kids AND post up a thread!! Obviously I can't walk and chew gum either! LOL!
I meant I will be going to CERAMIC brake pads on the Clubman!
Thanks for the heads up hemiheaded18!
Old Apr 8, 2008 | 06:58 PM
hemiheaded18
Sorry about the busting of stones. As an apology, is this what you were looking for:
http://new.minimania.com/web/Item/G2.../InvDetail.cfm is Green Stuff
http://new.minimania.com/web/Item/G2.../InvDetail.cfm is Red Stuff pads.
Old Apr 8, 2008 | 07:04 PM
toddtce's Avatar
toddtce
I am going to replace the brake pads on my Clubman with organic pads. I am OVER the brake dust issue....and the car is only 3 weeks old. I've already found a company for the pads and I'm thinking of pulling the rotors too and replacing them with cross-drilled rotors....
If your beef is with the dust, why in the world would you want to put a non blank rotor on your car? Any surface treatment is only going to promote faster pad wear and more dust.
Old Apr 8, 2008 | 07:19 PM
RaceFace's Avatar
RaceFace
LOL!! No stone bustin' here buddy! I appreciate the input. And THANKS for the links!
Old Apr 8, 2008 | 07:23 PM
RaceFace's Avatar
RaceFace
Thanks for the input!
I was looking for improved heat dissipation, which I was under the impression added life to the pad and the rotor.
Do non blank rotors cause the pad to wear faster?
Old Apr 8, 2008 | 11:05 PM
Robin Casady's Avatar
Robin Casady
What I've been hearing is the serious folks wont use cross drilled rotors for several reasons.
1. Drilling creates stresses that cause cracks when used hard.
2. Drilling removes mass, so less metal to absorb and store heat.
3. With modern pads, the outgassing rationale for drilling is gone.
Now days, cross drilled rotors main function is to impress 14 year-old girls.
Slotted rotors may be good for wet and dirty environments, but not that helpful otherwise. The serious racers seem to like solids.
The brakes on the 2007+ MCS are the JCW brakes of the R53. So, there isn't a lot of need for an upgrade.
I know all this to be true because I read it on the internet.
I've also been looking for replacement pads to reduce dust, and resist fading (not that I've run into that problem yet). The names that have come up are Hawk HPS, and Bobcat 1521. I don't know much about them yet.
Old Apr 9, 2008 | 05:32 AM
toddtce's Avatar
toddtce
You won't pick up any improvements of significant value with an aftermarket rotor. Granted the drilled rotor may shed heat a bit better with the air flow it provides but for the average street user it's not going to be a noticeable thing. Add to that potential for cracking and the elevated dusting levels and you'll simply be trading one issue for another. I have nothing against drilled rotors for street use, I think they look sexy too, but they'll always come with some trade offs.
And you'll be able to pick up 14yr old girls too...let's not go there.
Old Apr 9, 2008 | 06:30 AM
RaceFace's Avatar
RaceFace
I really don't need a 14 year old to tarnish my clean record, so it looks like I'm stayin' away from slotted rotors!!
But seriously, thanks for the info on the rotors. I will stay with the stock ones.
The pads I am interested in are from Carbotech. Anybody hear anything about their quality?
Thanks again!
marc0011
Sep 10, 2015 10:04 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Panik
Sep 9, 2015 08:36 AM
Sep 4, 2015 09:23 AM
TrueEddie
Sep 2, 2015 11:43 AM
