I need a straight answer on run flats
With few MINIs here in Maine, popular non-runflat replacements aren't available off the shelf either.
I saw a Toyota pickup with a flat tire on the side of the road today. It started me thinking. . . I haven't see a car on the side of the road with a flat in a long time. So I thought about all of the times in my life I've been on the side of the road with a flat. I could only think of three times (oh, many times in my driveway in the morning, a few times at work; and there were those pretty fast slow leaks). One was a blow out in a retread when I was in College. Another time in Mexico a tire we'd borrowed from some shop equipment (graduate school botanical expedition) and was probably 10 years old, failed. The other time was in summer in Arizona where the tire wasn't flat but the tread separated and flapped against the fender. I changed the tire but I could have limped to the next town as there was still plenty of air in it. None of these were in a MINI. College was thirty-five years ago.
Maybe the problem being solved with run flats isn't as great as most people assume. Let's see, in my life, stopped three times with flats and twice by accidents. . . .
I am a magnet, apparently. My 06 MCS has had one runflat replaced (under tire warranty for $25) due to a nail near the sidewall, and one other repaired for a screw in the tread. both were discovered at home, so no risk of being stranded.
I had 4!! nails in a span of 8 months in my old BMW. I guess I have bad luck.
That being said, I'll be ditching the runflats when they are worn out next summer.
I like the analogy of the NFL player in sandles . . . I think real people laugh at a performance car with runflats. I know it is a BMW thing . . . but then there have been famous and charasmatic Germans with bad judgement.
Though flats are an EV=P*C equation.
For a person unfamiliar with cars and/or unable/unwilling to change a flat in unpredictable circumstances, the 'cost' could be so high that even an extremely low probability makes the Expected Value (EV) high enough to justify the cost of runflats.
If you do go non runflats do not use Fix-A-Flat the stuff will stick to everything inside the wheel and is hard to get off. Slime kits include a compressor and slime for 19.95 at alot of auto parts stores or the Kit from Mini which is very expensive at 121.00. Both of the last two the "goo" can be cleaned out with water.
Woo!...i just put on my new SSR's and Goodyear F1 AS 215 45 -17 and it made a huge difference. Very solid around corners, more responsive to steering and suprisingly, cured most of my torque steer. Highly recommend Tirerack.
thanks....maybe i've found the name of my car, "Squidgy". Squidgygate refers to the pre-1990 telephone conversations between the Diana, Princess of Wales and a close friend, James Gilbey, and to the controversy surrounding how those conversations were recorded. During the calls, Gilbey affectionately called Diana by the names "Squidgy" and "Squidge."
My 2 cents
I just replaced our stock run flats with the Continental run flats. The have a AA traction rating and ride much nicer then the stocker for about $130 installed a tire. I race only a few times a year and the car is my wife's primary ride. I tend to like the idea that if she gets a flat she can drive home and pull into the garage and call me. I would tend not to like the idea of her bent over in a downpour trying to stick some aerosol can in a valve that she have never seen before and along comes Bulba in his pickup truck with the slanty "3" stuck to the side wanting to give her a lift
LoL Winter here like 49f at night
Run Flats stink in the winter unless they are A/S.
I decided to ditch them and am deciding on non runflats.
I have not had a flat in 10 years, but I willl carry my AAA Card, tire fix and a small compressor. Not a big deal for more comfort, and much lower replacement costs. 1/2 price for equivalent quality.
goodyear F1 A/S
I have to give it to Goodyear.. man these tires rock. these should be a standard. I switched from the dunlops RF, to these yesterday... wow what a difference. The turn in is much crisper and now i have a confidence with these that i never had with the dunlops. I would highly suggest these as a replacement from the runflats.
When you switch to non-runflats with the stock 16" wheel, do people typically change the size of the tire? I find very little for all season non-runflat tires in the 195/55-16 size. I'm guessing a few different sizes actually fit that wheel.
I run 205/45/R16's on the street. I'll likely switch to 215/40/R16's when I need new tires. On the track I run 225/50/R16's, but that's just because I got a killer deal on them. When they're toast i'll likely get some 225/45's.
Parada Spec-2's are Ultra High Performance Summer and the RT-615's are Max Performance Summer
Toyo Proxies 4 and Kumho ASX are both decent compromises for performance/safety if you get a lot of wet weather or light snow.
I'm surprised MINIHune hasn't chimed in, being our resident tire expert
Goodyear F1 All Season.
They handle and feel great.
About $146 tire installed at a Good Year dealer.
They have very new technologies built in like carbon fiber for some rigidity.
goodyear F1 A/S..etc.
I had forgot to mention that the super annoying torque steer that i had with dunlops has been fixed with the non rf's. unless i am REALLY get in it, there is no chirp or pull, comparatively.
It's as if i am driving a different car.
ltjpunk7
Sep 6, 2015 07:32 AM
Powershift
Aug 16, 2015 05:14 PM
