Rough Ride
Old Aug 31, 2007 | 06:23 AM
paradise190's Avatar
paradise190
Rough Ride
I have a 2005 Cooper S with very nice 18" Chrome wheels and low profile tires. It also has an aero kit. It looks great but this combo gives a very rough ride. What wheels and tires would smooth things out. Thanks
Old Aug 31, 2007 | 06:37 AM
wscruiser's Avatar
wscruiser
I don't think the aero kit has anything to do with the rough ride. A couple of things that others may need to know in order to help are; what size tires are you now running, and what brand are they? Has your MINI been lowered?
Old Aug 31, 2007 | 06:40 AM
Loony2N's Avatar
Loony2N
If you are running run-flats, get rid of them. If not, a higher profile tire will, obviously, smooth out the ride.
Old Aug 31, 2007 | 10:13 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Do you have stock suspension or upgrades?
When is the last time you had alignment done?
What are the alignment settings?- stock?
Rough ride can be caused by many things-
Bad uneven roads
Lower profile tires- 35 series
Hard or stiff sidewalls- BF Goodrich g-Force T/A KDW2
Too much air in tires- try 36 psi front and rear
Misalignment- toe settings not same right to left, too much rear camber from dropping suspension
Rim size is passively involved- smaller rims are light and allow for tires that are more comfortable, 18" rims are heavy and usually have small sidewall tires.
Broken suspension part like a worn shock
If you have coilovers that are adjustable try settings that are less stiff- try 30% less than full soft and adjust from there.
jeri534
Nov 6, 2015 01:40 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
gnhovis
Sep 28, 2015 10:56 AM
