help? Brake pad light just turn on
Hi everyone, I need some help. My brade pad light is on. I am in GTA. Anyone know if there is another place I can replace the pad other then mini dealership who can also reset the brake pad light on the dash? I do want to save some money!
Mini charge 186 for the front brake pad. Is this a reasonable charge?
thx so much
thx so much
How mechanical are you?
https://www.northamericanmotoring.co...ad.php?t=43438
This is for the rears, but I'm sure if you do a search there's a front DIY too.
Check your pad thickness visually.
With most wheels, you can look through the wheels and see the brake pad directly. The brake light will go off if EITHER the front or back pads are too thin, so you should examine them both to see which one is wearing faster.
OctaneGuy's how-to guide (referenced in message 2 above) has some great pictures that you can look at to compare.
