Upgraded divertvalve & boost tap
Engine - Intake/Fuel
  • Engine - Intake/Fuel - Upgraded divertvalve & boost tap - Used - -1 to 2027  All Models - Greenfield, WI 53221, United States
Community Builder
    $70
  • Location Greenfield, WI, 53221, USA
I'm selling my upgraded divertvalve.  It's the newer style and it came on my k04 , I upgraded the spring in it. As you see I run a dual spring inside. I used this same divertvalve setup on my last build and it was making 24psi and held it solid. On this setup I was making 23psi with this divertvalve.
I used it about 2x months and maybe 2k miles..
boost tap is brand new. It installs under the rear tmap sensor and allows you to run a boost gauge off true vacuum/boost not ecu calculated psi/vac..
70$ shipped to lower 48x. Paypal only.
pm or respond to this post.
Stay safe N mod on  !!!
Old Mar 13, 2026 | 06:20 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Old Mar 22, 2026 | 02:13 PM
MiniManAdam
Community Builder
Old Apr 4, 2026 | 07:18 AM
MiniManAdam
Community Builder
Old Apr 11, 2026 | 03:42 AM
MiniManAdam
Community Builder
IF your running more boost than stock via tune or plug in module, I highly suggest this divertvalve. It will help maintain boost without bleedoff and it makes the throttle boost rampin a little more aggressive.
Old Apr 21, 2026 | 12:56 AM
MiniManAdam
Community Builder
This is a great upgrade for running anything above stock boost levels.. it will make throttle snappier , build boost and hold boost better also..
plus , then you can run an ACTUAL boost gauge with the boost tap not a obd2 ecu calculated boost..
