Suspension Beginner Suspension Tweaking - What to do first?
Old Mar 16, 2007 | 11:35 PM
  #26
mini552's Avatar
mini552
Listen to those telling you to have some care with putting too stiff a rear bar on . . . I dialed my 19mm Hsport up to full stiff, and when I went through one of my favorite fwy ramps at speed, it definitely felt like the rear end wanted to come around. That said, I like my 19mm rear bar on medium settting, very light (10.6lb) 15s, KoniFSDs with JCW springs (yes I know Koni recommends no lowering - it's 1/2 inch, if that). I'm intrigued by the Ireland front camber plates, and if I had it to do over again, I might have gone with that first.
Old Mar 17, 2007 | 07:38 AM
  #27
Bahamabart's Avatar
Bahamabart
After reading NAM threads I did the following -
The first thing I did was a 19mm rear sway bar and the car became more neutral in the corners.
The second thing I did was swap out the run flats - big difference for me when pitching it into a corners as well as dealing with road transitions.
The Third thing was swapping out the stock shocks for a set of Bilstiens. The ride is about the same but produce less lean when tossing the car round.
These mods have raised my confidence and make for a nice daily driver.
Old Mar 17, 2007 | 08:47 AM
  #28
MY4thMINI's Avatar
MY4thMINI
great information ...i need to go shopping
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
vulkandino
Oct 31, 2015 08:29 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
