Suspension Front Swaybar Install How-To
Old Dec 5, 2012 | 03:42 AM
  #26
Jwp2's Avatar
Jwp2
Yeah...it's a PITA.
I sharpened one of my chisels and wedged it into the flange of the ball joint and just beat it senseless. Slowly it started to separate. Just worked each side back and forth until it finally broke free. The flanges deformed(bent) some but when you torque the bolts back down, they bend back into place. Of course, if you are replacing them, it's not an issue.
Good idea to soak the top of the ball joint itch penetrating fluid overnight if you can...that may help some.
Like I said...it's a pain....good luck!
Old Dec 7, 2012 | 05:42 PM
  #27
k_h_d's Avatar
k_h_d
Anyway to get the pictures back? How much different is the R56 to change out the front sway compared to the R53.
Old Dec 8, 2012 | 05:30 AM
  #28
Jwp2's Avatar
Jwp2
Originally Posted by Seattletimbo
Jwp2 Any luck? I am having the same issue. I tried a ball joint seperator and stripped the threads on the tool. Sooo frustrating! TIA
See the picture in post 17 above. That is the joint you have to separate. Just keep wailing on it side to side and it will come out.
Old Dec 10, 2012 | 02:07 PM
  #29
CrazyIvan's Avatar
CrazyIvan
You could always take the brake calipers and hang them. Then just undo the spindles from the shocks and drop it that way. Done it that way twice worked both times.
Old Dec 10, 2012 | 11:05 PM
  #30
ColinGreene's Avatar
ColinGreene
Yep, i would never break the lines open on the brakes.
saves you a ton of trouble.
Old Dec 12, 2012 | 07:30 AM
  #31
GreekDrifter91's Avatar
GreekDrifter91
Originally Posted by MINIGURU@WAY MOTOR WORKS
Just have to say that is a pretty good How to. I advise anyone doing this to go ahead and replace the front control arm bushings while you have it down. Plus that Front Sway makes the car feel so much more planted.
why would you want a stiffer front sway bar in a FWD car for? i understand poly bushings in controll arms(i have done that before), but why would you want more under steer in FWD?
does the combo of front and rear make i feel "planted", but wouldn't the front negate a little of the rear if you got both?
Old Dec 12, 2012 | 10:20 PM
  #32
ColinGreene
just add more rear than you need, it makes the car lean less.
Old Jan 28, 2014 | 11:35 AM
  #33
crazyworld's Avatar
crazyworld
If anyone is looking for the pictures that were originally posted with this how to like I was, there is a PDF version that someone has uploaded here. Hope it helps!
Nick
Old Dec 6, 2014 | 11:57 AM
  #34
Lex2008's Avatar
Lex2008
what about the exhaust after the downpipe? It obviously need to be disconnected to get the subframe down. Certainly for my 2008 r56 S. Ooops sorry this is Gen 1. Sorry guys.
Old Dec 6, 2014 | 01:13 PM
  #35
TVPostSound's Avatar
TVPostSound
Smack the lower control arm where the ball joint goes through.
A sudden shock in exactly the right place will cause sufficient vibration to force the balljoint taper to pop loose from its socket.
Done hundreds that way.
Old Oct 7, 2015 | 06:09 AM
  #36
BucksCountyR57's Avatar
BucksCountyR57
I know this is an old thread but I am doing this for repair purposes. I have a bad front sway bar bushing on the drivers side. I am planning on dropping the subframe but keeping it under the car (maybe we'll see if I have enough room) to fight less with my power steering reservoir. My MCS has the reservoir hidden in this tiny **** box.
Anyway...my question is. do you need to remove the left and right axle assemblies? I guess you can say I am still in R&D mode. Last night I just started to scout out my work areas and ID the things i need to keep in mind.
This is a great write up!!!! Saved the pdf to my computer too.
OR! Just brainstorming here...can't I just remove the subframe bolts, leaving everything in place to drop just enough to get a wrench in there to change the bushing out?
Old Oct 7, 2015 | 09:02 AM
  #37
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you want to go that route, we have a subframe DIY here that may be helpful to you. Since you'll be replacing the bushings, look into using the Powerflex front sway bar bushings PEL-PFF5-102-16 here.
888.280.7799 | 6am - 5pm PST
Old Oct 7, 2015 | 09:51 AM
  #38
BucksCountyR57
Thank you. I did see that and have read that. Although it is not my specific model and year I am assuming there will only be slight differences in the process. (I have a 2011 MCS Cab) Such as where the steering U-joint is located. I also watched a rather lengthy video online (again a different model year, Gen1 actually). Granted this video was about removing the clutch but it did involve removing the sub-frame.
That video recommended leaving the axle assemblies in place while your article, if i remember correctly, suggested that they needed be be removed. I am guessing removing the axles was for clearance purposes to wheel the sub frame out then?
One remaining question that I have (for now) is in regards to the power steering. Do you know if my model year actually has a reservoir or if being electronically assisted takes this out of the picture?
Thanks for the reply and link, it is very much appreciated
squawSkiBum
Oct 2, 2015 09:21 AM
FLYM1N1
Aug 15, 2015 11:20 AM
vicj
Aug 13, 2015 10:46 AM
tag1260
Aug 5, 2015 04:27 AM
