Suspension noise from front right...tie rod or bushing?
Old Mar 6, 2007 | 11:33 AM
mini_macky's Avatar
mini_macky
a few days after tracking my Mini, it started making this loud clunking sound when decelerating or crawling in traffic. haven't used it since.
took it to a few shops to have the suspension checked, and they said either it's either the tie-rod or front control arm bushing
i have a couple of questions...
1. when applying pressure to the control arm, it's moving by a couple of millimeters. is this normal?
2. on the tie rod assembly, is the "rod" itself supposed to be moving? (like a rolling motion)
any inputs would be great
Old Mar 6, 2007 | 11:34 AM
Dr Obnxs's Avatar
Dr Obnxs
I'd guess bushing...
because a lot of them have gone...
Matt
Old Mar 6, 2007 | 01:22 PM
mini_macky's Avatar
mini_macky
how should i be able to distinguish the sound between a worn tie rod & bushing?
last time i used my Mini, it only makes the sound when crawling in traffic & decelerating/braking.
Old Mar 6, 2007 | 02:45 PM
Dr Obnxs's Avatar
Dr Obnxs
Check out the thread on
front bushing failures. Basically you're looking for motion at the front control arm busing. A mm maybe, more and your looking at problems there. A shot tie rod would have slac as you tried to move the wheel like it moves for steering.
Matt
Old Mar 7, 2007 | 12:59 PM
onasled's Avatar
onasled
lose wheel bolts...
silence2-38554
Nov 12, 2015 09:39 AM
maestro39
Oct 27, 2015 02:38 PM
FLYM1N1
Aug 15, 2015 11:20 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
