Suspension Lower Control Arm Torque specs?
Old Feb 27, 2007 | 07:33 PM
gnhovis's Avatar
gnhovis
Reverse
I searched for it and couldn't find it. Bentley manual says 74 ft-lb for upper control arms -- same for lower? Thanks.
Old Feb 27, 2007 | 07:43 PM
txwerks's Avatar
txwerks
74 is the number for both...
Old Feb 27, 2007 | 07:59 PM
onasled's Avatar
onasled
74!?? For the control arms? Somehow that doesn't sound right at all. As I remember it was closer to 41.
74 would be more like the trailing arm to bushing bolt. I don't have my book, but maybe you should double check that.
Old Feb 27, 2007 | 08:39 PM
txwerks's Avatar
txwerks
Page 330-16 in the Bentley...
Control arm to rear subframe and to trailing arm (M12 x 1.5) - 74 ft/lbs (100 Nm)
You want to torque them only after the car is on the ground and loaded normally.
41 is for the swaybar link to trailing arm, swaybar link to swaybar, wheel hub to trailing arm, rear strut upper mount to strut tower and a myriad of other stuff...
Old Feb 27, 2007 | 09:34 PM
onasled's Avatar
onasled
Thanks for clearing that up.
You also state "You want to torque them only after the car is on the ground and loaded normally." I still am unsure whay this would be any kind of issue on any suspension part with the exception of the rear trailing arm to bushing bolt.
But maybe I'm just thinking hiem joints with the trailing arms. Are you concerned about locking in the rubber trailing arm bushing and possibly having them preloaded when dropping the car? I know meb was always pushing this same thing. Thanks
Manny_cooper
Nov 4, 2015 09:42 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
