Suspension Spring Clearance
Old Feb 7, 2007 | 11:42 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Spring Clearance
Yesterday I had IE camber plates and 4 rear control arms installed. My car is a 9/02 built 2003 MCS with stock springs and dampers.
Current alignment specs:
front camber -2.0º
front toe in 0.05º
rear camber -1.6º
rear toe in 0.05º
There is no spring rubbing with stock springs except through turns. I have read into what txwerks recomends here . My questions is this, has anyone done nothing and had the grinding stop? Meaning, once things get settled and the springs grind a spot for themselves or the body grinds the springs there will become clearance, thus silence. After about 50 miles on my setup the sound is not as pronounced. Idealy someone will soon sell stock ride height springs that are slightly smaller in diameter yet the same linear rate, and compatable with the stock dampers.
Old Feb 14, 2007 | 12:09 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Update: After about 350 miles on this set up, the springs no longer rub. So they worked out a place for themselves. For all who want radical camber with stock springs, don't worry set it as you want it will work out.
M7Speed
Jul 10, 2018 09:26 AM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
nshannon29
Sep 30, 2015 05:21 PM
