Suspension Rear Swaybar Install Materials
Hi,
I have the H&R 19mm rear swaybar and am having it installed on Friday. I bought the adjustable endlinks from Texas Speedwerks, but other then that, all I have is the bar.
Do I need anything else in order to have the bar installed?
mb
mb
The H&R 19mm rear bar comes with the larger bushings and does not need lubrication. You have all you need and should be good to go. If you've had your car for a while and have never made a suspension change like adding a sway bar you might want to start out with the lower (less stiff) settings for a little while until you get used to cornering with the reduction in oversteer. Then bump it up and enjoy the handling change! I added the 19mm H&R to both of our MINIs a year ago and have been very pleased with it on the streets, AX and track.
Yea I was thinking that for the front, but I thought it too late. I'm going to hold off on the endlink and bar install for now - I have a few months before track season starts up again.
Thanks for the tips!
mb
mb
squawSkiBum
Oct 2, 2015 09:21 AM
bctf1
Aug 6, 2015 12:55 PM
