Suspension Koni FSD vs. OEM SS (non-plus)
Old Nov 20, 2006 | 02:41 PM
  #26
meb's Avatar
meb
Anyone install camber kits with these?
Old Nov 20, 2006 | 07:16 PM
  #27
rkw's Avatar
rkw
Originally Posted by caminifan
Koni sells a FSD + aftermarket spring combination.
Koni offers this for some cars, but not for MINI.
Some people are reporting good success with FSDs and H-Sport springs:
https://www.northamericanmotoring.co...ad.php?t=74526
https://www.northamericanmotoring.co...ad.php?t=72626
https://www.northamericanmotoring.co...ad.php?t=78577
Old Nov 21, 2006 | 05:51 PM
  #28
mini552's Avatar
mini552
Originally Posted by rubyred3
FSD= Frequency Selective Dampers
The frequency response of a suspension is dependent on:
The mass of the item suspended
The spring rate
The damping rate
Koni engineered the frequency response of these shocks for each specific application using stock springs. Change the spring rate, and you change the frequency response outside of how it was designed to perform. Doesn't mean it won't work (people run lowering springs on stock shocks all the time, which is pretty much the same sort of thing). More than likely, it will give you a car that feels slightly underdamped, i.e. one that "bounces" a bit instead of having that firmly damped feeling.
This topic has pretty much been beaten to death in other threads - mostly concerning use of FSDs with Hsports as documented by Scott at Central Coast Coopers. Different posters have cited different conversations with different Koni reps - bottom line seemed to be that in order to work properly, the FSDs had to have enought susp. travel - and that if a moderate (say up to 1" drop) lowering spring was going to be used, the special bump stops that restore lost travel (such as come with Hsports) was a good idea. I personally doubt that Koni specifically engineered the FSDs to cover the difference between the "sport" and "sport plus" (MCS) springs available on the MC. I think any MC FSD shock set comes matched to the length of spring travel in the Cooper and a spring rate range covering both the susp. options - i.e. I don't think they're valved differently between sport and sport+.
smdmini
Oct 7, 2019 06:05 AM
ej
Nov 17, 2015 09:21 PM
Ladybug-S
Sep 10, 2015 07:08 PM
mikeson
Sep 6, 2015 06:21 AM
