Suspension Megan Coilovers - MEB where are the directions?
Old Jul 11, 2006 | 03:39 PM
defylogik's Avatar
defylogik
Megan Coilovers - MEB/msfit directions/help?
getting a set of megans soon, and i cant seem to find these infamous MEB directions to help with installing them.
do these exist yet, or am i on my own? any tips from those that have them installed on proper setup, etc?
thanks.
scott
Old Jul 11, 2006 | 08:25 PM
defylogik's Avatar
defylogik
any help out there ?
i am primarily interested in what stock rear upper mount parts that i need to reuse, do i need to reuse my bump stops, best way to adjust them without removing them from the car, etc.
thanks in advance! i am desperate..
Old Jul 11, 2006 | 09:12 PM
SpunkytheTuna's Avatar
SpunkytheTuna
Originally Posted by defylogik
i am desperate..
Nah, you're not desperate yet. They haven't even arrived yet. Desperate is when it's 4:00 AM on Monday morning, all of the suspension is off the only car you have, you need to get to work in 4 hours, you can't find a 37cent bolt that you need to put any suspension member back on yet, your pregnant wife is going into labor, the dog is barfing into your shoe, you drop a spanner on your forehead and can't see for the blood in your eyes so you roll over onto the work light, burning your cheek just before the bulb shatters and gives you a mouth full of broken glass and you still don't have the damned directions, your phone's been disconnected and your cell phone battery is dead.
THEN you're desperate.
Right now you're just anxious.
Old Jul 12, 2006 | 06:06 AM
meb's Avatar
meb
I am finished with the rear instructions, but I need to remove and re-install a front damper in order to complete the front set of instructions.
Until then, anyone can PM me with questions, or call me. I'll leave my cell # in a return PM.
defylogik,
I sent you a PM.
Michael
Old Jul 13, 2006 | 08:56 AM
mangotangoe's Avatar
mangotangoe
Would also like to know what stock rear upper mount parts that i need to reuse...
Any help appreciated.
Old Jul 13, 2006 | 11:16 AM
meb's Avatar
meb
The flange, the upper and lower flange bushings, the dowel, the larger up-turned washer that sits ontop of the upper bushing and the two bolts that attach the flange to the body, and the lower bolt.
Old Jul 13, 2006 | 11:38 AM
mangotangoe
Does the rear oem strut have to be disassembled to remove any of these parts? If so, I guess I will need a spring compressor.
I plan on setting the new struts to be 1 inch shorter than stock and use this as the baseline. Just received my Megan's yesterday. The included documentation is pretty rough. Here is one page...
File Type: pdf
Old Jul 13, 2006 | 12:11 PM
meb's Avatar
meb
you need a spring compresser to remove the stock units, but not for the Megans.
Old Jul 13, 2006 | 03:57 PM
BradB's Avatar
BradB
I am about ready to pull the trigger on the Megans. Can anyone verify if I can use the front M7 strut tower reinforcement plates with the Megan coilover kit?
Also, I would very much like better installation instructions as well if anyone can help me out.
Thanks!!!!!
Old Jul 14, 2006 | 05:05 AM
meb's Avatar
meb
Yup! I have the M7 strut bar - this includes the strut tower braces.
As a side note, my Megans came with nuts threaded to the three studs on top of the red anodized camber plate. I removed these so that the camber plate sits flush with the bottom of the strut tower. with the M7 braketds above, the strut tower is sandwiched between the two. I've never had a problem with mushrooming since.
THE INSTRUCTIONS WILL BE COMPLETED BY JULY 31, 2006 - with some photos
Old Jul 16, 2006 | 11:41 PM
CynMini's Avatar
CynMini
Right on!!
Old Jul 17, 2006 | 05:09 AM
meb's Avatar
meb
Where do you good kind folk want the instructions to be? I can include pics and text here or in a new thread entitled Megan instructions.
Maybe these should be posted on the Megan site? If I place too many pics in my gallery I will not be able to update. Any suggestions are welcome but keep in mind I'm a very old computer moron.
Old Jul 20, 2006 | 09:08 PM
defylogik's Avatar
defylogik
hey if you need any help with illustrations or making them look nice lemme know. i do graphics for a living
oh yeah on another note, i dont know if you mentioned it, but on the spring is a number stamped onto it, the middle number in this sequence( xxx-xxx-xxx ) is the spring length in mm i believe (someone confirm) if you set the distance from the top of the spring to the bottom to that number you will have no preload starting out. use calipers (digital works best)
Old Jul 20, 2006 | 09:15 PM
SRTech's Avatar
SRTech
Mine have settled a little since I installed them (10,000miles) and I had to tighten them by about 5mm to keep them from rattling. I did Scooby03's also since they had loosened up.
Steve
Old Jul 20, 2006 | 10:34 PM
CynMini's Avatar
CynMini
Steve
So what it be a good idea to start out with about 5mm of preload so you don't have to go back and tighten?
Old Jul 20, 2006 | 10:52 PM
CynMini's Avatar
CynMini
Question for Meb, a little OT,...
or anyone else who wants to chime in. Lets say Im a little on the poor side right now and I don't want to buy and install both the Megans and an H-Sport Comp bar at the same time. I want to get the Megans right now. Do you think I can dial out a lot or all of the understeer by running the rears a few clicks stiffer? I did this on my Honda Si and it worked well, actually I was able to fine tune the balance for different canyon roads this way.
Old Jul 21, 2006 | 04:03 AM
meb's Avatar
meb
ABSOLUTELY! Remember, the rear spring rate is quite a bit higher than the front. When I installed mine, I had the stock bar. I set the front dampers at 12 from full hard and the rear 11 from full hard.
The Webb bar is on the soft side of the middle setting and it was a hair too much bar for Watkins Glen where the dampers where equal front and rear.
Old Jul 21, 2006 | 07:43 AM
SRTech's Avatar
SRTech
I wouldn't start out with a preload. After doing Brad's, I preloaded mine a little and they still needed tightening. I'm not sure if mine compressed more because of that or not, but it's easy to take the slack out later if they do settle. Make sure that when you tighten the lock rings, you really crank them down hard because they tend to come loose if you don't.
Steve
Old Jul 21, 2006 | 02:29 PM
gmcdonnell's Avatar
gmcdonnell
QUIT SPYING ON ME!
Old Jul 24, 2006 | 07:41 AM
Smooth is Quik's Avatar
Smooth is Quik
Install instructions
Patiently waiting for your instructions.
Old Jul 29, 2006 | 03:59 PM
Smooth is Quik
Yup!
less then two days left,
Old Jul 31, 2006 | 05:06 AM
meb's Avatar
meb
I just returned from an unexpected business trip - I've been out of the area for 10 days but I'll see what I can put together.
I was hoping to have two new front dampers in my hands by now - for goofs and giggles. I do not want to take the front end apart without the new dampers in hand otherwise this becomes a very time consuming task for the purpose of instructions only.
I will offer this as a go forward; I'm assuming that everyone has a Bentley Manual and so any info regarding the removal and reinstallation that is TYPICAL will not be part of the instructions. The major part of the instruction will be focused on adjusting the Megans before they are installed, and, how to drill the holes in the rear so that the dampers can be adjusted.
Sorry about the delay, but big business got in the way.
RIchard Nguyen
Sep 14, 2016 11:43 AM
sssevita
Mar 20, 2016 06:24 AM
minimofo
Dec 26, 2015 12:03 PM
tristanwelch95
Sep 30, 2015 08:58 AM
Emnotek
Sep 29, 2015 07:37 AM
