Suspension Powerflex front control arm bushings installed
So all 6 or 8 bolts will have to be unscrewed, thecontrol arms detached from the knuckle etc, and the steering rack seperated...Powerflex should make this a part of the bushing, it should not be an option. I'm beginning to lose interest in this car.
I am about to install these on my 03. I have the motorsports add on kit also (just a washer and bolt). It says in the basic kit instructions to roughen up the inside of the factory tube with sandpaper - I guess this is why! Is it the outer or inner part that walks rearward? If it is the outer then I may glue it in. I was hoping I could add the motorsports brace only for track days - but it sounds like there may not be enouigh room without dropping the frame - isd this correct?
Can anyone tell me how to delete a double post - sorry about the above.
Wes
PS - I added Ireland rear control arm bushing inserts last weekend and am so far very happy with them. Only slightly more rear noise on grainy pavement and notisably better contol over bumps in corners (less bump steer). I am worried about them working the bolt loose though and will check torque again thie weekend.
Wes
Wes
Wes
Originally Posted by J Propane
Thanks K-Huevo, that's exactly what we did. Didn't know they were available!
They may be recommended for Motorsport usage, but the first time they came out, is the first day the car backed-out of the shop. Way before we hit the track.
If it was my street car, I wouldn't consider installing them unless the support was used.
I have two cars with these and no problems, even after a day at the drags.
meb:
this is your chance to rough up some knuckles. If all you are doing is lowering the subframe a bit, loosen the crush tube bolts, (no need to pop the front end,) grease up your arm to reach into where the steering knuckle is, disconnect the two 13mm bolts holding each hub ball joint, you may get away with leaving the tie rod ends hooked up, otherwise a conventional puller gets 'em, get an air impact wrench to loosen the 6 or 8 bolts, you are really only talking about a couple of hours, start to finish.
meb: I'll second JLM's comments. It doesn't mean yours came apart. It only happened to one side on our car, for some reason. Perform a visual check first!
002: They split between the 2 bushings.
Edit: Don't bother explaining it. Seacrest out.
jlm, J Propane - thanks, I'll give it a try. Gotta get the parts first. Mine arestill fine, but I'm not taking any chances.
I'm really puzzled about how these came apart...why do you think J Propane? I can understand if the front control arm ball joint was faulty, but that component essentially keeps the bushing in place...???
Michael
Michael
I guess a picture is worth a thousand words.
The screw worked itself loose and fell. And yes it was loctited!
Edit: Ok now I see, the inner bushing is on the wrong side of the carrier. Phew, I thought I was going crazy.
J Propane, Have you had a chance to install these in the correct order yet? I think your concerns will be gone with them installed right. Also, let us know how hard it is to remove the outer bushing from the carrier.
Edit: This is not a smart a$$ remark, if that is why there hasn't been a response.
Originally Posted by jimz68
I called BMP/Pro MINI (where I bought my bushings) and they have not yet heard of the Motorsport Support Kit. Can anyone let me know where they found it?
Thanks!
Jim
Thanks!
Jim
It is a bolt and oversized washer that threads into the rear of the control arm to sandwich it together and prevent foward movement of the arm when accellerating. I'm not sure how it will affect suspension geometry through the range of motion.
Thanks!
Jim
Thanks!
Jim
Originally Posted by k-huevo
Powerflex offers a motorsport support piece PFF5-101MS. I know there is an allen bolt on the end of the trailing arm I would assume this part would replace. For the street this looks like it would be a little more restrictive; maybe a harsh ride. There's a picture on this page http://www.powerflex.co.uk/products....7&submit1.y=11
pure&simple, any chance you'll be installing these yourself, or like meb, utilizing a professional? If the former, kindly share some details, and if not much trouble, some photos (of the install)... Either, look forward to hearin your impressions afterwards! Thanks.
I'll ask him if he'll be willing to document the job for posterity. Tentatively scheduled for 7/10-7/11.I will certainly share my impressions, but my perspective will be a little different as there are some other changes in the mix. I'm having Eric remove my tubular front control arms (with Delrin bushings) and reinstalling the stockers (with Powerflex bushings) for peace of mind on the track. Also, the H-sport front swaybar is coming out, and the OEM bar is going back in, also with Powerflex bushings. I've really enjoyed it, but decided it was just a bit too much for the street, lifting wheels out of every parking lot and exaggerating rough roads. I'm hoping I won't lose too much of the steering responsiveness I've grown to love... we'll see.
I've heard that Eric is a heck of guy, and really knows these cars. Good for you! I'm sure he's quite busy, but if he can document it, great.
Hey, if you consider parting with that bar, let me know, as I might be interested. Heck, all that stuff sounds interesting! Well, if you plan to part with them, kindly PM me.
Thanks much.
Thanks much.
Thanks much.
Thanks much.
