Suspension Koni FSDs
Old Jul 13, 2006 | 06:10 AM
  #76
obehave's Avatar
obehave
Originally Posted by Larry Clemens
...WTF..LOL..please spell out the acronyms so us old dudes know what you're talking about
I am an old dude
My OEM struts will EOL ASAP so SYLA POS Delphis I'm going FSD & JCW
My Original Equipment Manufacturer struts will End Of Life As Soon As Possible so See Ya Later Alligator Piece of Sh** Delphis I'm going Frequency Sensing Dampers and John Cooper Works.
Not entirely grammatically correct but I was going for humor not accuracy. I hope I got close.
Old Aug 2, 2006 | 09:38 AM
  #77
trentf's Avatar
trentf
I had KONI FSDs installed w/ Hsport springs by Central Coast Coopers in Oxnard, CA on Saturday and had the wheels aligned today at EF1 Motorsports in Signal Hill, CA.
This is the best mod I have done so far (..OK maybe tied with the 15% pulley). The car feels more like a junior BMW M3 now, it is no longer harsh over uneven roads and handles significiantly better.
If you want more info - I can't stop talking about the FSDs send me a PM and I'll give you my phone #
Had the FSDs and H-Sport springs installed this past weekend at Central Coast Coopers. Thanks to Scott and his crew out there in Oxnard !
The set up is absolutely awesome! This is how a MNI should drive. Also had installed 2-pair of Noltec rear control arms. Will post alignment specs soon. Can't be happier about this!
Old Aug 10, 2006 | 08:18 PM
  #78
caminifan's Avatar
caminifan
Well, they (FSDs) are on my MCSa....
For my needs (minimum ride harshness), the combination of the Sport Suspension springs (what my MCSa came with from the factory), 16 inch /50 series non-runflat tires and FSDs is the current state-of-the art. I took a longer way home that had some challenges (purposely drove out of my way to find a section of street that was ground down for re-paving - now there is some rough roadway) to try out the FSDs. Now, you hear the roadway's bumps and roughness more than experience it. There remains some residual roughness, but it is nowhere near what was before.
FSDs = (out of 5 possible score). A highly recommended modification!
Old Aug 10, 2006 | 08:26 PM
  #79
DrkSlvrS's Avatar
DrkSlvrS
trentf - I was told that the FSDs would not fit on an '02????
Enlighten me ... did you have to modify anything?
T
Old Aug 10, 2006 | 08:59 PM
  #80
Central Coast Coopers's Avatar
heres the deal on the early car
if you have a pre 3-02 car, the UPPER SPRING MOUNTS AND SPRINGS ARE DIFFERENT. the sway bar end link mounts on the strut housings are different as well ==HOWEVER if you want to install lowering springs, you will need all of the top mount items from the spring upwards-about 110.00 at your MINI dealer. We have done one coversion of a very early 02, the first S ever sold in Hollywood, and it worked out fine/springs only. we have not done any fsd conversion on an early car, it will require a later front sway bar and end links, at the least. Trents car was built after 3-02.
Old Aug 11, 2006 | 10:44 AM
  #81
trentf's Avatar
trentf
What Scott said!
T
Hi DrkSlvr,
Have been away from things lately, sorry for late reply. Basically, Scott explained this perfectly in his message after yours. Mine is an Aug02 build so I didn't have this issue. If your quest is for better ride quality and improved handling at all points, you will not be disappointed!
Trent
RobbyD
Jan 29, 2019 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
rt808
Sep 29, 2015 03:15 PM
Emnotek
Sep 29, 2015 07:37 AM
