Suspension Strut Brace, which one?
Old Mar 3, 2003 | 08:42 AM
Phobol's Avatar
Phobol
I see Randy is selling two different ones, same price, I was just wondering wich one is better, if anyone tried both or whatnot.
Old Mar 3, 2003 | 08:37 PM
MiniPilo's Avatar
MiniPilo
to my knowledge, the BMP only works with the BMP Filter
Old Mar 3, 2003 | 09:01 PM
Mister_S's Avatar
Mister_S
I think BMP/PROMINI also sells a modified factory airbox cover to work with their stress bar. I have to say, I really like the eccentric adjuster/preloader on the BMP/PROMINI design. That combined with welded aluminum construction makes it, in my opinion, a lot of hardware for the money.
Then again, you could probably weld a piece of angle iron between the two strut towers and achieve the same effect.
Good luck deciding!
James
Old Mar 3, 2003 | 09:15 PM
Phobol's Avatar
Phobol
Thanks! I'll try to figure it out. I'll also ask Rspeed about it.
Old Mar 4, 2003 | 12:06 AM
Rocketboy_X's Avatar
Rocketboy_X
As far as I've seen, all of the strut braces require some filter box futzing..
Rocketboy_X
Old Mar 4, 2003 | 05:53 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The BMP is the best one out there in my opinion. You do need to use the lower profile air filter however. This isn't such a bad deal though, as the fit and finish of the unit is superb, and you do gain some power as well.
Let me know if you have any other questions.
Randy
Old Mar 4, 2003 | 03:42 PM
audball's Avatar
audball
Randy, will you please be sure to comment on the strut bar that (optionally) comes with the camber plates that are in development when you get your evaluation set?
Thanks,
Dave
>>Randy
Old Mar 4, 2003 | 03:45 PM
Nobull60's Avatar
Nobull60
_________________
Old Mar 4, 2003 | 03:50 PM
TwOMINIs's Avatar
TwOMINIs
Is there anything out there that will work with the Madness intake? To strut or not to strut, that is the question.
His, Chile Red all over / Hers, EB UJ on top
Old Mar 4, 2003 | 06:16 PM
TheBluePotato's Avatar
TheBluePotato
To clarify a few things - We (Rspeed) are selling 2 different ones as we are an authorized BMPd dealer and Moss Mini Dealer - also, you do not need to use a lower profiled air box top - it is the ECU cover that needs to be modified - which is provided for free with the BMPd Strut Bar. You can see it in Bruce's picture above.
If I had an S, I'd have the BMPd bar on it in a heart beat - excellent quality - comes in 3 flavors and is such a "beefy" looking support for your Cooper. Makes a noticable difference in high speed cornering and makes the Cooper even more rigid.
Go with the BMPd bar - it is well worth your inventment.
-Peter/Rspeed Mini
_________________
R*Speed Mini Accessories*Performance*World Class Service
http://www.rspeed.net
1011 S Marietta Pkwy, Ste 4
Marietta GA 30060
1-888-551-0025
<A HREF=http://www.rspeed.net><IMG SRC=http://www.rspeed.net/images/banner_rspeed_mini.gif></A>
Old Mar 4, 2003 | 08:26 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Dave,
I will comment on the entire setup after the evaluation. Here are the teaser photos that I'm sure you've already seen:
TwOMINIs,
The Madness heat shield can be notched to work with the BMP, it just takes a little fabrication. Outline where it will be after taking some measurements, then cut the shield with some tin snips, use some weather stripping available at any NAPA, and mount the stress bar.
Randy
720-841-1002
Old Mar 4, 2003 | 08:58 PM
foldinghalo's Avatar
foldinghalo
I just ordered mine last night.
Old Mar 5, 2003 | 10:59 AM
dave's Avatar
dave
pug poo picker-upper
As a mechanical engineer, I really like the looks of this. Very nice.
_________________
folded: 565 origami cranes
to go: 435
YahooIM: denvermini
Old Mar 5, 2003 | 11:10 AM
8ball's Avatar
8ball
>>As a mechanical enginer, I really like the looks of this.
... yeah ... makes you wanna go out and Adjust it ... just 'cause you CAN!
Old Mar 5, 2003 | 11:15 AM
dave's Avatar
dave
it's funny cause it's true.
Old Mar 5, 2003 | 11:54 AM
Mister_S's Avatar
Mister_S
Peter, can you further clarify? This is a quote direct from the PROMINI (BMP) description of their stressbar: "Installation requires the low-profile filter cover, or the ProMini racing air filter kit." Can I use the BMP bar with the stock airbox?
Here's a link to the PROMINI page if you need to take a look:PROMINI/BMP Parts Page
To clarify....................you do not need to use a lower profiled air box top - it is the ECU cover that needs to be modified - which is provided for free with the BMPd Strut Bar......................
-Peter/Rspeed Mini
Old Mar 5, 2003 | 07:54 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Every BMP stress bar I've installed (with my own hands ) has been in conjunction with the filter. I don't think the stock box would work with the bar.
Peter is right - the ECU cover is modified also, and it comes with the stress bar. I really think you need the BMP filter, or at least a notch in any other filter system, to make it work. I don't think the stock box gives you enough room.
I'll look the next time one of the customers with the stress bar stops by.
Randy
Old Mar 6, 2003 | 03:49 PM
Nobull60's Avatar
Nobull60
Randy I checked and you CANNOT use the BMP with the stock box. I was cleaning mine today and put the old box on to check. It hits the top and cannot connect to the other strut bracket. So if you want a BMP strut brace it looks like you need the BMP intake to go with it. Not a bad choice and they look good together.
Old Mar 22, 2003 | 05:52 PM
foldinghalo
I just received the BMP bar today. Thanks Peter! Just a quick question or two (there were no instructions). The red anodized bit, does it matter which way it faces? I’ve seen it both ways in some of the pics posted, although the official BMP photo shows it towards the firewall. Does it have to be torqued to a a specific spec or just screw it down nice and tight.:smile:
_________________
Old Mar 22, 2003 | 08:05 PM
Sleepless's Avatar
Sleepless
Randy
What is the poop on that bar with the adjustable camber plates? Can you give us a hint as to what it will cost and what is the camber adjustment range? When will it be ready.
Stop teasing us
Old Mar 23, 2003 | 03:55 AM
jlm's Avatar
jlm
I am manufacturing the plates and bar. so far, there are 5 sets out there on cars and a few sets on order. Retail is $650 for the plates; add $150 for the bar. To install them, you need to remove the coilover and replace the stock rotating bearing assembly with the piece in the kit. The bar requires that you have clearance in the intake and ecu cover. The ECU cover is a $10 plastic part that snaps on and can easily be modded with a notch.
more here:
http://www.mini2.com/forum/showthrea...900#post320900
Old Mar 23, 2003 | 10:58 AM
Priscilla's Avatar
Priscilla
I realize that Randy (aka the resident guru ) is out of town so an answer may be slow in coming but what is the story with the H Speed bar. Is it a rebadge of one of the existing bars or is it a new product with better/ differenct fitment options?
Old Mar 23, 2003 | 11:02 AM
Azwed's Avatar
Azwed
Ackk I thought the same thing.
Back back back ME's I left that major three years ago.
Old Mar 26, 2003 | 11:51 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I am still working on these camber plates with jlm - in fact I need to talk with him tomorrow on an issue relating to this.
That issue still prevents me from selling them just yet, but jlm is selling them like gang busters.
Once I know they are ready, I'll be selling them, and the cost has apparently gone up form the last time I talked with John - I'll let you know tomorrow.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
buggyeye401
Oct 1, 2015 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
