Suspension M7 Springs/ Koni Shocks
Hi Folks
Got M7 springs and was planning on just using them with stock shocks.
Sorta change in plans and thinking of adding Koni Yellow Shocks.
Basic questions:
1)Is this setup is ok?
2) Whats your experience with koni yellows? - are they good shocks or is it just a brand name?
3) If i go springs & shocks .. will this require me to add something else?
I use the car for street only.
Cheers.
Basic questions:
Cheers.
The stock shocks are not well suited to lowered or higher performance springs. While they are good quality, they will wear and fail prematurely when combined with springs not matched to them. Konis are an excellent shock, their reputation is well deserved. They balance well with aftermarket springs for the MINI, and are fully adjustable allowing you to tune the ride you want. For street use you don't really need anything else. For track, you would do well to add rear adjustable control arms, and front camber plates to allow for optimum alignment and camber settings.
I had the koni yellows and m7 sprigs and didnt like it at all, I think the valving on the koni's is a bad match for the rates on the m7 springs. I couldnt find a happy medium in settings ont he shocks to make it livable. I know a ton of people with koni shocks that love them and there are a bunch of people with m7 springs that are very happy. I just dont know anyone who has both and is happy. I switched to pss9's and have never looked back.
Hm.. things arent looking too good for me.. starting to think that getting these springs were a mistake coz they'll ruin my shocks eventually unless i get aftermarket shocks.
What shocks suits the M7 springs then? only pss9's?
aren't you getting a little ahead of yourself? Most people that bought M7 springs use the factory shocks and most like the ride. I've only seen a few reports of clear premature shock wear, some report over 10K of miles without any problems. Then there is one report from one person not liking the springs with yellow Koni's. I say, go with the factory shocks and see if you like it, then keep your eye on aftermarket shocks. If you do the spring swap yourself a second swap, of the shocks, will be way easy...
Hey mate
- Understand and agree with u about 'getting ahead' of myself re: springs with stock shocks etc.
However I have the chance to get some Koni yellows cheap - which is why iam trying to find out if they are suitable with M7 springs. Otherwise id be wasting my money if i didnt bother looking into it
Also - i will have an idea which shocks are suitable, incase i DO experience premature shock wear.
Hope this gives an insight to my questions.
Cheers.
Cheers.
RobbyD
Jan 29, 2019 01:22 PM
pahg
Oct 5, 2015 11:50 AM
Emnotek
Sep 29, 2015 07:37 AM
, before they show wear
