Suspension Camber toe curve
Old Apr 20, 2006 | 06:25 AM
  #26
waldvogelmj's Avatar
waldvogelmj
Originally Posted by meb
Why so much rear camber?
I took the alignments of you, Minihune and someone else (forget who) and had them do basically an average. Minihune and the other guy both had -1.6 in the rear with no toe.
Old Apr 20, 2006 | 09:46 AM
  #27
BLIZZ's Avatar
BLIZZ
0 toe in the rear is o.k., but normally the car drives better with a little toe in on the front {say 1/8" total toe} or toe out if setting up for autocross.
I think most people have found that camber seems to have a good balance if 1 degree more negative camber up front compared to rear camber.
If you like the way your car drives.....leave it alone.
Old Apr 20, 2006 | 10:26 AM
  #28
waldvogelmj
The guy doing the work told me a car tends to toe in under speed. I've never heard this before, but he advised against toe in. I would have liked a little more negative camber in the front, but the Megan's are difficult to adjust and I could tell my time on the rack was up.
Old Apr 20, 2006 | 12:21 PM
  #29
meb's Avatar
meb
Our banter here basically illustrates a very important point; where you begin and what assumptions you make determine where you'll end up...I little more camber in the rear adds a stabilizing affect and 1.6 is not overly aggressive. The other way to slice bread would have been to dial in a bit of rear toe in and less negative camber. Tuning is an iterative process and the outcome, again, is based on what ever else you've done. BLIZZ wrote it all, if you like, drive it!
Hell, mine came back from the shop with over 3 degrees negative camber in the back and so much toe in up front it was off the scale...among other things...I didn't like it...in an hour I'll get my ride back...we'll see. I've been very hyper lately and it's due to rushing and surprises...I hate surprises. I hope the alignment feels good this time.
Doc Pain
Mar 10, 2021 04:50 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
fkrowland
Sep 30, 2015 10:30 AM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
