Suspension Change springs and shocks on MINI Cooper. Whats next?
Ortho Jr.,
I think you mis-understood what I wrote; indeed, a bar that is too large can ruin an independent suspension design - I agree completely! Weight transfer is shared by springs, dampers, AND swaybars. To what degree depends upon what % of distribution each take on. Take the stock Mini for example; if the sway bar sizes front and rear are increased by 50% for example, the handling balance will not change, but responsiveness will be quicker.
Also, what Kenchan wrote, "depends upon what else you've done", is correct; soft springs allow a given bar to come on-line faster than heavy springs; soft springs allow a bar to twist faster. Here, it's a mater of steering angle.
Originally Posted by orthomini_jr
I'm going to have to disagree with you there, partially anyway. A sway bar is another way to stiffen the suspension. Putting big sways front and rear can be like putting 1000lbs springs on. The problem with it, even not taking it to that extreme, is that you're taking the independant-ness out os the suspension. Also the quickness of the weight transfer depends on the shocks.
Maaij and Snid -
It sounds like you replaced your stock Cooper SS (not SS+) suspensions with aftermarket.
I actually have an 02 MC with standard SS (not SS+), but before the changes to the suspension were made in 03 to a slightly softer setup. I am actually looking to get a bit softer setup, and am considering installing a later version of the stock suspension, after the "softer" setup was incorporated, to swap with my original setup, in the hope of getting a bit softer more comfortable ride.
If either of you, or anyone else, has a stock MC post-03 SS suspension setup, or even just shocks, that you would like to unload, let me know as I may be interested in taking them off your hands.
Thanks,
Don
d_p@earthlink.net
503.975.7470
Thanks,
Don
d_p@earthlink.net
503.975.7470
andrewjg1994
Jan 29, 2021 07:45 PM
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
