Suspension Input needed in suspension choice
Originally Posted by Stevie B
I think all other options including aftermarket coil overs (don't be technical here, you know what is meant), lowering springs and all other shock options will only decrease an already less than ideal ride quality. All I want to do is correct the stock suspension flaws so as to provide more fun driving, and I drive moderately aggressive (even by German standards).
As to the JCW suspension, see this
On difficult, tight runs the MINI with JCW sports suspension can be steered even better into bends. The slightest of steering-wheel movements are enough to maintain the MINI on course. The inner front wheel maintains contact with the road surface, thus allowing the MINI to accelerate faster out of the bend. … I wholeheartedly recommend the JCW sports suspension to adventurous drivers, who like nothing better than taking to country roads and winding mountain routes.
http://motoringfile.com/2004/11/12/j...sion_in_detail
Addin the JCW suspension made the car MUCH easier on my bad back than stock. Significantly enough to be felt.
Originally Posted by chows4us
Sorry, got to disagree here. 1mm more on the rear bar isn't going to do much of anything. With the 25.5 H-Comp on the softest setting, the car still understeers.
I thought the stock bar was 16mm? Most report that figure. Anyway, there's a lot more to the dynamic than just the thinkness of the bar. My goal is less understeer, and I'll probably go with H&R's 19mm 2-way adjustable (+3mm). Here again, I'm just trying to enhance the package, not change it radically. My plan is for no fuss. No suspension settings to mess with on the Koni FSDs and no lubrication required on the H&R bar ("Ever"). I'll definitely set to softest setting and may change if the understeer is still more than I want.
19 and 22 are standard choice. Some ppl are fine with 19. Most go with 22. In the end, its all a personal choice.
The H-comp is effective 22. There is still understeer. Oversteer dont both me .... we are used to it, Just got to know what to do when the rear end comes around
Hmm, I thought it was 17 but not sure.
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Minibeagle
Aug 13, 2015 10:00 AM
