Suspension H&R's or H-Sport's, which is better performing?
Old Dec 7, 2005 | 06:56 PM
koenner1's Avatar
koenner1
which is a better performing spring? (strictly for track perpose. comfort is not an issue.) H&R or H-Sport?
Old Dec 7, 2005 | 07:16 PM
kenchan's Avatar
kenchan
on stock struts? H-Sports.
but make sure you get a larger rear swaybar....otherwise just leave it stock.
Old Dec 7, 2005 | 07:18 PM
koenner1's Avatar
koenner1
thanks. i appreciate it. would they still be the best with KONI shocks (the yellow ones, i believe they are called the KONI Sports)
Old Dec 7, 2005 | 07:27 PM
onasled's Avatar
onasled
Also, I have seen that the H&R have a slightly larger diameter then the H sports. This in turn will get you less negative camber if you decide to use camber plates. About one degree less then the H sports.
Old Dec 10, 2005 | 05:55 PM
DK23's Avatar
DK23
I have H&R with the Konis and camber plates. I have -2.25 in front, -1.7 in rear. Track handling is excellent. The H&R were not well suited to the stock shocks, adding the Konis transformed the handling and ride.
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 01:10 PM
Sep 2, 2015 01:08 PM
Sep 2, 2015 12:57 PM
Sep 2, 2015 12:55 PM
