Suspension do you have this problem?
Originally Posted by detlman
I didnt mean to discount what you said about the short wheelbase.
Perhaps aspects of the car being front wheel drive have an impact as well, since meb has a Honda that does it too (although I'm not sure which Si it is). The M Coupe also does not do this over the same surface and I don't recall the SO's S2k doing it over similar surfaces and that had an x-brace as well. Anyway, I like to think of it as a cool 'Mini' thing that it happens so easily and looks even more toy like
Can you add a little more rebound...this might help
I need to do th equaife next, I get alot of insde tire spin in some uphil corners where the turn is tight and you need to try and use all th epower we have.[/QUOTE]
I have pss9 coil overs with an r-speed 22mm rear bar set on the middle setting.
thanks, and I do like jacking from one spot to do both tires !
UncDeo
Nov 4, 2019 04:08 AM
Navigation & Audio Portable Navigation XL Wiring
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
