Suspension Deal on Rear Strut Tower Bar
Old Aug 7, 2005 | 08:12 AM
  #51
NearlyNN's Avatar
NearlyNN
Originally Posted by Joe Donovan
I've talked with drivers of gutted dedicated MINI race cars (one just yesterday) They all agree that the people who benefit from the rear bars, for MINIs, are the Companys that sell them!
I don't doubt that this is the feedback one receives from race-prepared cars. However, it might not be on point. In fact, it might actually argue for the bar.
Let me explain. Joe, I believe what you are relating. I have heard the same thing , in a sense. Remember though, these cars have a minimum of 6-point roll cages. Every roll cage supplier, or fabricator out there that I've spoken with has told me that the addition of a cage will greatly stiffen the car and improve handling. This in itself, is evidence of potential benefits. Whether some of these benefits can be gained by a rear strut tower brace are certainly questionable.
I don't want to go with a cage at this time. Yet, my SOP tells me that more body stiffness would help. Not very scientific.
Where I feel the need is on tight, slow turns. With our long gearing (03) one has to work hard at getting the car rotated fast and back on the throttle. If I can, I like to bounce the inside rear off the curbing, turn the car and gas it. It's entirely possible that stiffening the body in the rear may actually be counter-productive, since it may reduce one's ability to "kick out" the back. I'm still running that through in my head. Maybe worth a try though.
This product, for my purposes, then might be wrong on two counts: One - it may not do anything. Two - it might defeat what I am trying to accomplish. I just don't know, but appreciate the feedback.
Old Aug 7, 2005 | 10:24 AM
  #52
J0kER's Avatar
J0kER
any reasons why....did they give U' good cold facts? or just opinions..cuz everybody has them & well you know the rest......i've got one on and will say it works to stiffen cabin but not so sure on suspention????
Old Aug 8, 2005 | 07:00 AM
  #53
jimz68's Avatar
jimz68
Originally Posted by joker
did U' try to fit this and no luck?
Yep. Sold to me as fitting all models. Tried to install and it was way too tall, bonnet would not close. Went to OMP's website and found that it was listed for MINI and MINI One only. Not MCS. Live and learn.
Jim
Old Aug 8, 2005 | 09:14 AM
  #54
J0kER's Avatar
J0kER
thx a million...
thx jim for clearin' this up. i own a Mcs & was going to try this one in place of the one i currently have...... sorry to hear that ur stuck w/it maybe U should try ur luck selling it here theres plenty of mini one owners on here!
Originally Posted by jimz68
Yep. Sold to me as fitting all models. Tried to install and it was way too tall, bonnet would not close. Went to OMP's website and founfd that it was listed for MINI and MINI One only. Not MCS. Live and learn.
Jim
Old Aug 8, 2005 | 09:34 AM
  #55
NearlyNN's Avatar
NearlyNN
Jim
Might need a clarification here. Looks like this may be another case of confusing the OMP front strut tower brace with the universal rear brace that is found further down the page:
http://www.motorspot.com/strut.html
I say this, because you mention closing the bonnet.
I'm curious about the "universal rear". Thanks though, sure this info will help others looking at the front brace.
Old Aug 8, 2005 | 10:51 AM
  #56
rkw's Avatar
rkw
Jim
Was it the same OMP strut brace that was fitted (successfully) here: http://www.mini2.com/forum/showthread.php?t=93751
Old Aug 8, 2005 | 11:23 AM
  #57
J0kER's Avatar
J0kER
is it part #1747 b or a states "universal" and has a tension screw on it. cuz thats the one i thought U were talking about?? that part # does look like it will need drillin'
Old Aug 8, 2005 | 11:26 AM
  #58
J0kER's Avatar
J0kER
hey rkw hows it going, no the one jim refers to is the front brace piece....up top
Old Aug 8, 2005 | 11:38 AM
  #59
NearlyNN's Avatar
NearlyNN
Thanks for the link, but these are front braces. See below
Old Aug 8, 2005 | 11:40 AM
  #60
NearlyNN's Avatar
NearlyNN
is it part #1747 b or a states "universal" and has a tension screw on it. cuz thats the one i thought U were talking about?? thay one does look like it will need drillin'
Yes, joker those are the ones I'm wondering about. The rear strut tower "universal brace" in either steel (A) or aluminum (B).
Old Aug 8, 2005 | 11:51 AM
  #61
rkw's Avatar
rkw
Yes, I think this is a somewhat off-topic side discussion. Jim mentioned issues with closing the bonnet and I assumed he was referring to the OMP front strut brace. I was curious whether it was the same product that other people apparently had success with.
Old Aug 8, 2005 | 12:22 PM
  #62
andy@ross-tech.com's Avatar
andy@ross-tech.com
Agreed. Add to that, the fact that the MINI doesn't even have rear struts! The rear suspension does not use the top shock mount to keep the suspension geometry fixed (which is what happens in the front end of the car). Instead, the rear top shock mount simply serves as a place to connect the spring and shock to the body. Moving this mounting location left or right doesn't affect the suspension settings (this is why you don't see camber plates for the rear suspension). The trailing arm and locating links do all of the rear suspension geometry control. Buying a "rear strut brace" for the MINI makes no sense from a logical performance standpoint.
Old Aug 8, 2005 | 12:27 PM
  #63
J0kER's Avatar
J0kER
and this is the exact explanation i was wanting.......so do U' agree that this part will only help w/cabin flex??
Old Aug 8, 2005 | 12:39 PM
  #64
andy@ross-tech.com
If a giant pair of fingers were squeezing the cabin together directly over the rear wheels, and if that turned out to be a bad thing, then yes, a rear "strut" brace would probably help with that.
Old Aug 8, 2005 | 06:17 PM
  #65
jimz68's Avatar
jimz68
Looks like it. But notice how it bends up and over the ECU and fuse box. On my car, at least, I would of had to remove or trim the under-hood liner for the hood, sorry, bonnet, to close properly.
Jim
Old Aug 8, 2005 | 07:19 PM
  #66
J0kER's Avatar
J0kER
yea...i woul'nt want to cut mine either!!
thats to-bad looks like a nice design too.....
Jim
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
