Suspension Are the bump stops really necessary?
Old Jun 9, 2005 | 04:26 PM
dominicminicoopers's Avatar
dominicminicoopers
Are the bumpstops on the shocks really necessary on the MINI, or are they there for added "piece-of-mind"?
Old Jun 9, 2005 | 04:33 PM
MSFITOY's Avatar
MSFITOY
Yes, they are very necessary to prevent the shocks from bending their shaft when metal meets metal at the end of their travel...not good when you bottom out:smile:
Old Jun 9, 2005 | 04:35 PM
dominicminicoopers
So this is the reason why when putting lowering springs on the car, people cut their bumpstops in half rather than removing them outright, correct?
Old Jun 9, 2005 | 04:39 PM
MSFITOY's Avatar
MSFITOY
I don't know about other springs but HSport provides short hard rubber bump stops. I don't know of any circumstances when you could use shocks/spring of any type without bump stops.
Old Jun 9, 2005 | 04:50 PM
dominicminicoopers
So if I got lowering springs that didn't come with bumpstops, and I decided to cut the factory ones in half to retain the suspension travel, I should keep the harder of the two halfs or the softer?
Old Jun 9, 2005 | 05:09 PM
MSFITOY's Avatar
MSFITOY
Definitely the harder. The bump stop is your last protection when the suspension reaches their limit. A lowered spring provides less travel to reach that point:smile:
Old Jun 11, 2005 | 12:39 AM
Dr Obnxs's Avatar
Dr Obnxs
Keep the harder, but it's not that simple.
To make sure you don't bottom more, you have to have the same amount of energy in the springs for the deflection (less with lowering springs) that it takes to bottom the suspension. So a lowing spring that is soft will need a harder bumpstop, but a much stiffer spring aready limits travel more, and the softer one will be fine.
But really, without all that mumbo jumbo, without bumpstops, when you bottom your suspension, all those metal on metal parts act like ball-peen hammers on each other. Something is going to give, and it won't be pretty! Think of the bumpstop as a reusable crumple zone in the suspension. It should reqire lots of energy to deform (be very stiff) so that it lessens the metal on metal impact.
Matt
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
Oct 1, 2015 07:05 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
