Suspension "clunk" when turning slowly
Old May 4, 2005 | 02:00 PM
  #26
E1Designs's Avatar
E1Designs
Took mine to Ralph Schomp (Denver), and of course they could not reproduce. The day was rainy and I had to drive a distance. I was unable to reproduce with the tech in the car. He did say there was a known steering rack issue on 02-04 and MINI corrected it for the 05's. I know am feeling it again, mostly left and it is very annoying. I own an 05 with NO mods, nothing. Obviously I need to get this corrected before any mods are done, or they will for sure point the finger.
Pete or anyone else anything specific I can point out to the dealer? Are you for sure this is under the car not in the steering cloumn? Man I want this resolved...only got about 2800 miles on the car also.
Old May 4, 2005 | 02:18 PM
  #27
meanboy's Avatar
meanboy
Originally Posted by Veni_Vidi_Vici
The problem turns out to be the bearing casettes in the H-Sport camber plates. According to the fine folks at Eurostyles the bearings were rusted badly enough to look like "they've been underwater for a year". Since the cassetes aren't covered by the Hotchkis warranty Eurostyles is pulling apart one of the H-Sport plates they have in stock so that they can repair mine.
I think that's a lot better then a bad steering column. BTW, it's been 1k miles since the replacement and so far so good.
Old May 13, 2008 | 05:21 AM
  #28
MINIdriver85's Avatar
MINIdriver85
I have this same issue. My suspension mods are JCW shocks, Eibach springs and Ireland Engineering adjustable camber plates. I'm going to take my car to my mech tomorrow for checking on another noise and will have him take a look, hopefully it's not the steering column as I plan to get BC coilovers soon so if it's only the camber plates I can live with it for another couple of months.
Old May 13, 2008 | 06:24 AM
  #29
checkmate2006's Avatar
checkmate2006
From putting the rear top hats did you leave out the spacer sleeve. I hadn't done this and it made the craziest clanking noise. I took the spacer sleeve out and got the top nuts tightened all the way down and the whole thing is so much tighter now.
Old Jun 21, 2008 | 08:53 PM
  #30
ittle85's Avatar
ittle85
well...crapola. when i turn my wheel to the right when i am at a stop OR driving, this is...90 degrees, there is a big "CLUNK" i have a 03. My father is a mechanic, he's been at it since he was 17 so I'm going to ask him...
I have an 03'....
Old Jun 22, 2008 | 10:38 AM
  #31
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
I have an 03'....
How many miles? I'll bet you have a bad half-shaft.
Old Jun 22, 2008 | 11:25 AM
  #32
JAB 67's Avatar
JAB 67
My '04 MCS with original and unmodified suspension has started doing this as I approach 75K. Most common scenario is after pulling into a parking spot with wheels cocked to the right; when I go to leave by putting car into reverse and turning wheel to opposite lock, within a few feet I sense a 'clunk' in the front suspension as if some bearing or bushing is either loose or worn out. Likely candidates would be top strut mount bearing, ball joint, or lower control arm bushing (aka the 'lollipop' bushing.) Any suggestions on how to isolate the precise culprit?
Old Jun 22, 2008 | 08:59 PM
  #33
ittle85's Avatar
ittle85
50,000
Old Jun 23, 2008 | 02:13 AM
  #34
mimilo's Avatar
mimilo
Hi!! i have the same problem, i hear a clunck at low speed, sometimes when i accelerate, and when i stop. When i turns right or left, in the driver's side, i think its something in the suspension near to the left wheel, But only in slow speeds.
I think its a suspension issue more than something with the steering column.
How could i know the difference?
Old Jun 23, 2008 | 09:03 AM
  #35
JAB 67's Avatar
JAB 67
bump
Old Jun 23, 2008 | 11:42 AM
  #36
ittle85's Avatar
ittle85
okay i'm sorry. what is a bump?
Old Jun 23, 2008 | 11:50 AM
  #37
AstroBlackS's Avatar
AstroBlackS
most likely the front lower control arm bushings. I had a clunk coming from the rear, turned out to be my top strut nuts. They were not tightened all the way down
rob&JCW
Feb 21, 2018 02:41 PM
wildwestrider
Dec 27, 2015 08:20 PM
rob&JCW
Oct 9, 2015 11:12 AM
renchjeep
Sep 6, 2015 01:54 PM
Suspension Products
Sep 2, 2015 10:32 AM
