Suspension Recommended alignment specs?
Old Apr 11, 2005 | 08:55 AM
mburchill36's Avatar
mburchill36
Hi all -
I need a little advice for some work I'll be doing on my '03 MCS. I'm going to be putting in a set of M7 springs with lower rear control arms and an Alta 22mm rear sway-bar later this week.
Can anyone recommend alignment specs for this set-up?
I've seen some people suggest the following:
FRONT-
1/16" toe out.
-1.5 degree camber. (I won't be using camber plates up front yet, so I'll have whatever the stock config creates after lowering)
REAR -
zero toe.
-.8 degree to -1 degree camber.
How's this sound? Would you suggest anything different? Is there a good source of information for recommended settings anywhere?
Just for the record, I'm a fairly aggressive driver and I do auto-x several times a year. The car is my daily driver too.
Thanks in advance!! - - Michael
SneedSpeed
Sep 21, 2015 06:06 AM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
hydouken
Sep 15, 2015 05:49 AM
