Suspension Strange Popping sound with PSS9
Old Apr 4, 2005 | 02:29 PM
samawil's Avatar
samawil
Hi,
I just installed some Pss9s on my MCS, and now there's a strange popping sound coming from the front (both left and right) when I turn the wheel at 0-low speeds...has anyone else experienced this?
If so is it normal and will it go away, or is there something wrong?
It almost sounds like the springs are snapping up and hitting something, but I'm not sure
Thanks for any info...
Louay
Old Apr 4, 2005 | 10:09 PM
pfunk's Avatar
pfunk
Friend of mine just got a set too and had the same problem. I believe you have to put some kind of spacer in the front.
Old Apr 4, 2005 | 10:55 PM
samawil's Avatar
samawil
between the caps and the coils?
the instructions call for them but I didn't have them anymore so we went without...
That sucks cuz now it's basically like starting all over again...what did your friend do?
L
Old Apr 5, 2005 | 02:36 AM
SpiderX's Avatar
SpiderX
Mine were installed at R Speeed and I have no noises
Old Apr 6, 2005 | 04:31 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by samawil
Hi,
I had PSS9s installed this week. No noise. Sheer bliss!
Popping sound? see
http://www2.bilstein.de/en/produkte/faq.php3
From the FAQ:
64. BILSTEIN shocks make a noise.
On the spare part set the support bearings ( dome bearings ) should also be exchanged because the metal-rubber connections become soft or crack. Although you might not have previously noticed any noise, you may hear a metallic knocking noise when new shock absorbers have been fitted. This is very often caused by the support bearings. A wrong sequence in the assembly of the fittings can also lead to noise.
Colt45Magnus
Aug 27, 2024 05:03 AM
embiggenedmini
Oct 15, 2015 12:36 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
tylewis
Sep 6, 2015 01:07 PM
wildwestrider
Sep 4, 2015 06:25 AM
