Suspension H-Sport Spring w/bumps Stops
Old Mar 31, 2005 | 07:18 AM
djafactor's Avatar
djafactor
Hello,
I had H-Sports springs installed with the H-Sport bumpstops. The bumpstops are a lot shorter than the stocks and allow for more suspension travel. However I'm having a lot of rubbing problems now. I'm running 17" OZ Superleggras w/37mm offset on Yok ES100 215/45/17 tires. Tomorrow I'm going to try trimming the fender liners but am fearing that the extra inch of suspension travel is still going to cause problems. I may have to switch back to the original bump-stops, but was looking for any alternate suggestions. I haven't found anyone with a similar set-up to mine to compare notes with. I should have know better before switching the bump-stops having the 37mm offset wheel, but I didn't think it would be that different. I do run the car at the track 6 times a year on 225/50/15 OZ superleggras with R compunds (37mm offset as well, from my '02 MINI on stock suspension) so I am thinking about camber plates in the future
Any help is appreciated from you suspension/tire gurus.
Amit
Old Apr 2, 2005 | 06:39 PM
Dr Obnxs's Avatar
Dr Obnxs
Look Here.
https://www.northamericanmotoring.co...ad.php?t=40371
Matt
Old Apr 3, 2005 | 11:07 AM
Ryephile's Avatar
Ryephile
Your tires are too big and your offset is too aggressive, of course you're going to rub. The bumpstops have nothing to do with it
patsum
26
May 29, 2021 06:29 PM
smdmini
Oct 7, 2019 06:05 AM
Sep 3, 2015 02:06 PM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
