Suspension Eibach Pro-kit springs, any good?
Old Mar 28, 2005 | 04:24 PM
kyriian's Avatar
kyriian
im torn with these and the h-sport springs... im lookin to match them to probably koni yellows, or more likely bilstein sp's... im just wondering are they linear or progressive... what is the rate of these springs... i think lowering the back more than the front can set the weight of the car back... isn't that a good thing?
thanks... i also want to ask if the bilsteins are worth the money over the konis
Old Mar 28, 2005 | 05:05 PM
Coop d'etat's Avatar
Coop d'etat
I called up Eibach once and talked to one of their techs...he spent about 30 min explaining their springs better than any info I ever got over the internet. You should give it a try I know they arent the same company, but I would assume that most companies would extend the same courstesy. I learned exact spring pressures, whey they choose to use those pressures, and also explained why some cars get progressive, some linear, and some a mix
Old Mar 28, 2005 | 05:36 PM
TheBlackBrian's Avatar
TheBlackBrian
I can tell you that as soon as I auto-xed with the eibach's alone, my times droped at least a second. Which in autox is a lot.
Old Mar 28, 2005 | 05:43 PM
dominicminicoopers's Avatar
dominicminicoopers
Originally Posted by Coop d'etat
...I called up Eibach once and talked to one of their techs... I learned exact spring pressures, whey they choose to use those pressures...
Please add the Eibach info to this thread. Thanks!
https://www.northamericanmotoring.co...ad.php?t=39371
Kimolaoha
Dec 5, 2020 09:32 PM
jeremy_reyes94
Sep 6, 2019 07:53 AM
melscoop
Mar 30, 2016 06:56 PM
Bennyboy
Aug 18, 2015 07:28 AM
OutMotoring
Aug 6, 2015 09:32 AM
