Suspension Wanted: Aftermarket spring info
Old Jun 29, 2005 | 12:42 AM
  #26
fs-mini's Avatar
fs-mini
Originally Posted by dominicminicoopers
Yes, that would be nice. :smile: Do you have links to pix I can put up?
Sorry I don't, but I bet there should be a number of pics showing H-Sport, M7 and Alta in this Suspension category. Or, any one who wants to post theirs, here is the place, and you can find the best ones to post.
Old Jun 29, 2005 | 01:08 AM
  #27
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For Bilstein PSS9 coil overs:
The ride height for both MC and MCS is adjustable from nearly stock to scraping the tires (slammed).
From-
https://www.northamericanmotoring.co...highlight=PSS9
325lb/in front springs - progressive
345lb/in rear spring with a 115lb/in tender or helper spring - linear
For any adjustable coil overs you can just list drop as "adjustable".
Right now for my MCS I have about a 2" drop front and rear.
Old Jul 6, 2005 | 09:47 AM
  #28
matma92ser's Avatar
matma92ser
https://www.northamericanmotoring.co...tachmentid=796
(edited text)
H-Sport is on left, and M7 on right.
Old Sep 17, 2005 | 05:59 AM
  #29
minigolf's Avatar
minigolf
15 September 2005: April 04 MCS on stock springs (205/45/17s)
17 September 2005:
April 04 MCS on Eibach Pro-Kit springs (205/45/17s)
Cheers Liam
Old Sep 19, 2005 | 01:36 AM
  #30
si_power's Avatar
si_power
Anyone knows the rate of Eibach, front and rear?
I heard that the OEM shocks are adjustable, as in we can adjust the height of the springs if it's too low. Is it true, That sounds b/s to me though. Anyone got pics of the OEM standard shocks?
Old Nov 2, 2005 | 07:36 PM
  #31
RandyBMC's Avatar
RandyBMC
Temporarily Banned
What can I do to help? I think you have already posted most of the info I've tested out...
I'm here!
Thanks,
Randy
Old Dec 17, 2005 | 10:07 AM
  #32
dominicminicoopers's Avatar
dominicminicoopers
Anything posted in red in the first post is what I'm missing. If you have any other springs you know of that are not on the list, then please post info here. :-)
Old Dec 17, 2005 | 06:35 PM
  #33
mvalant's Avatar
mvalant
What I find most interesting is that different sets have different relative rates from front to rear. Some sets have a slight front bias, some are pretty much the same front and rear, and some have a much stronger rear spring. It sems to me that the sets which have much stronger rear springs might not work well with a 22mm rear bar. Is there any truth to that?
Old Dec 17, 2005 | 06:49 PM
  #34
chows4us's Avatar
chows4us
No JCW? ... Oh yeah, thats CRAP, I forgot, sorry
Old Dec 18, 2005 | 05:37 AM
  #35
dominicminicoopers
At the time this was posted, there was no JCW. If you have any JCW stats, please post them and I will edit the first posting.
Old Dec 18, 2005 | 04:55 PM
  #36
911RSAmerica's Avatar
911RSAmerica
I just installed a set of PSS9's in my 05 MCS. I set the ride height in
the middle of the permissible adjustment range, measured for the top
edge of the spring seat down to the center of the bottom mounting screw.
Front permissible adjustment range 210-230mm set at 220mm drop LF 1 3/16" RF 1 1/4"
Rear permissible adjustment range 175-195mm set at 185mm drop LR & RR 1 1/16"
The permissible adjustment front and rear is 20mm so from the middle setting the car
can be raised or lowered 10mm (0.394")
The Drop range is:
Front ~7/8 to 1 5/8"
Rear ~5/8 to 1 1/2"
David K.
Old Jan 18, 2006 | 10:25 AM
  #37
jonsibal's Avatar
jonsibal
Here is another set of lowering springs for you guys..
INTRAX Lowering springs
Progressive type
Drop Range:
Front = 1"
Rear =.75"
Spring Rates:
Front = 262
Rear = 228
Got a set for sale here...https://www.northamericanmotoring.co...d.php?p=781257
Old Jan 18, 2006 | 10:37 AM
  #38
pooch1's Avatar
pooch1
Old Mar 30, 2006 | 06:27 AM
  #39
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Well I finally got some springs and a sway bar on my car. What a huge difference.
I took some before and after pics of the ride height for anyone who is interested. I put on H&R springs w/ stock struts/shocks and a MINI-Madness rear sway bar. I hope this helps anyone who is interested
BTW, there is nothing artistic about these images, just before and after. It was to early in the morning and I was to tired afterwards to be anywhere close to creative. Oh, blackspyder thanks for the help on these.
Front Before & After
Rear Before & After
Angle Before & After
Old Mar 30, 2006 | 06:51 AM
  #40
Jenn B's Avatar
Jenn B
Completely stock
M7 Springs
I love that pic, it really shows how nice and low she is.
Old May 2, 2006 | 08:16 PM
  #41
guidmini's Avatar
guidmini
M7 SPRINGS sit too low in rear
All input is welcome. I just installed my m7 coil springs today. The rear is just sitting to low. around streets ride is very harse and kindy bumpy on the FWY its fine. have alot of Mini owners experience the same problem with the M7 coil spring. The front sits nice. The rear is too low. The tires are almost squating going much too negative on the camber.
I see jenn. Installed M7 springs ? how is your ride around city driving.
I see Eibach H sports after the results it looks nice.
anyone with pics of there car with M7 springs pls post pics.
Thanks Guido.
Old May 2, 2006 | 09:14 PM
  #42
ingsoc's Avatar
ingsoc
Here ya go, d00d. https://www.northamericanmotoring.co...ad.php?t=55539
Old May 10, 2006 | 05:13 AM
  #43
Jenn B's Avatar
Jenn B
I have absolutely no problems with mine. My camber is perfect and it's not a Lexus, the ride isn't going to be like silk. But I don't consider mine harsh at all. Pretty comfortable and most importantly, the handling is great.
Old May 17, 2006 | 07:20 PM
  #44
LiLOreo's Avatar
LiLOreo
Anyone have Tein S springs, if so how do you like them?
I just ordered a new set of wheels/tires 18's & the tires are 215/35/18.
cant wait to get em on!
Old Nov 21, 2006 | 05:31 PM
  #45
drflowers's Avatar
drflowers
2 questions
1. What are the spring rates of the stock Cooper S Cabrio?
2. What are the spring rates of the Cooper S SS+ suspension.
I have added a 19mm rear sway bar and it feels much better, but still has a bit of a push. 20-30% stiiffer rear springs should do the trick.
Old Nov 22, 2006 | 06:34 AM
  #46
txwerks's Avatar
txwerks
Our TSW springs - 200 f/r linear
Stock springs - 165 f/r linear (NOT 225/200)
Our TSW Leda rates:
Sport - 250 f/275 r
Softcore - 325 f/r
Hardcore - 450 f/r
Old Nov 29, 2006 | 10:37 PM
  #47
Jtrem's Avatar
Jtrem
eibach offers two different kits though
Old Jan 29, 2007 | 02:14 PM
  #48
180MotorSports's Avatar
180MotorSports
Vogtland springs
MC Drop: 1.2" fr / 1.2" rr
MCS Drop: 1.2" fr / 1.2" rr
Rate:
Old May 9, 2007 | 05:23 AM
  #49
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
M7 Coilovers
Spring rates (standard): 240/280
Fronts have separate ride height and spring preload adjustment
Rear has spring preload adjustment
Old Jun 21, 2007 | 01:06 AM
  #50
GrossmeisterB's Avatar
GrossmeisterB
I just read this thread, and saw that there's only one set of H&R springs listed...
But (at least over here in germany) there are 2 (3) different sets!!
First there are green springs, lowering rated at 30mm, for all cars from 03/2002 onwards. then there are 30mm springs, which are black, for cars up to 03/2002 production date.
and there are the "red" ones, the "sport" version, rated at 35mm lowering...
So, I think that's the reason why some post a 30mm drop, and some 35mm drop!!
