Suspension Mini r56 alta 22mm bushings squeak
Old Apr 22, 2019 | 08:58 AM
kucils69's Avatar
kucils69
Old Apr 22, 2019 | 10:01 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Huh, just last weekend I removed, cleaned, re-greased, and re-installed the bushings on my Alta 22m RSB. Not because there was any squeaking but after 6 years I figured it was time to check on things. I used Powerflex PFTE grease left over from some other project.
I think WMW and NM have bushings/brackets with a zerk fitting for easy greasing.
Old Apr 23, 2019 | 03:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Try this: wrap the bar at the bushing location with Teflon plumbers tape, then install the bushing over the tape. Should last years longer than grease. On all my sway bar installations over the years, that’s how I’ve handled poly bushings from squeaking.
Old Apr 25, 2019 | 07:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We see it all the time on those Alta bars as the bushings wear smooth and loose all the grease.
You can do a swap and upgrade to our bushings with the grease channel that will keep the grease in and working a long time.
https://www.waymotorworks.com/22mm-s...shing-set.html
IQRaceworks
57
Feb 26, 2014 07:38 AM
astroBlackMetallic_Mini
Suspension
Aug 15, 2013 08:19 PM
custard
Suspension
Feb 18, 2009 01:26 PM
miniconcarne
Suspension
Sep 15, 2007 12:35 PM
fafnir
Suspension
May 16, 2006 10:25 AM
