Suspension Vibration after lowering
Old Mar 31, 2006 | 05:31 PM
  #26
MINIMAX 1's Avatar
MINIMAX 1
>> I have H-Sport Springs and have never had any problems or any noticable vibrations. Although I have herd this before from one of my friends. He still has not found what it is exactly.
>> MINIMAX1
Old Apr 2, 2006 | 08:01 AM
  #27
meb's Avatar
meb
The vibration is back with a vengance . I'm looking into this with help.
Old Apr 6, 2006 | 02:04 AM
  #28
fj0's Avatar
fj0
I just got some H&R coilovers on my car and I am experiencing the vibration mostly in 1st and 2nd but a little in 3rd as well. It's in the range 2000-4000rpm.
Someone must have resolved this! Help.
Old Apr 8, 2006 | 01:17 PM
  #29
e-mini-Austin's Avatar
e-mini-Austin
It seems that it took 2 or 4000 miles before the vibration set in. It is a high harmonic vibration that is only when under load. Clutch in it stops, off the gas, it stops. Mini factory guys say the problem is axel alignment with M7 springs. Or any other lowering springs. I have tried two sets of wheels and tires.
The factory guys say it will get worse, but on this thread some say it should get better.
Please repost if your problem got better
Old May 4, 2006 | 10:46 AM
  #30
ilscoobydooll's Avatar
ilscoobydooll
any news on this i have the same problem started out as a simple vibration now its it more like a super shake shakes the steering wheel and the shifter alot....only under medium to heavy load usually around 3-4k is where it is most promonent. also every once in a while it doesn't do it as much.....replacing my worn cluth and tob and flywheel in a couple weeks maybe that will fix it.
Old May 4, 2006 | 11:12 AM
  #31
jblow's Avatar
jblow
As one looking to fit aftermarket suspension on my '04 MCS, I'm a little concerned reading this thread as well as the GRM article. Will there be vibration problems with any aftermarket lowering springs?
Old May 4, 2006 | 12:17 PM
  #32
e-mini-Austin
I just changed back to stock springs and it fixed the problem. As best as I can tell from hearing of hundreds of conversions from the manufacturer, no problems. So, I think that I probably have a car with some slight problem in the CV joint that is magnified with the axel angle change. It seems to have to be an individual car problem and very few at that.
Old May 4, 2006 | 09:43 PM
  #33
Strom's Avatar
Strom
I had the vibration at first, but it has gone away after ~3k miles.
Old May 5, 2006 | 06:44 AM
  #34
meb's Avatar
meb
Vibration still present. It comes and goes with the frequency of raising and lower the car on and off my hydraulic jack. I think it is related to axle/CV joints.
I feel the vibration on the right side - passenger side. I'm perplexed. Last week, nothing, last night, worse than ever.
I'm going too fast at the track to notice in this environment
Old May 18, 2006 | 02:57 AM
  #35
fj0's Avatar
fj0
I still have this, help!
Old May 18, 2006 | 04:53 AM
  #36
Wagnbat's Avatar
Wagnbat
I'm now lowered on Megans, and I get a small but notice-able amount of 'shudder' under medium to heavy load, in every gear. If I'm doing 70 on the freeway, and give the Mini a stiff push up to 75, I can still feel the same level of shudder in the steering wheel, as I do when I launch from a red light at casual speed.
So if it's an axle angle issue, lifting or lowering the front further should fix, no? My front is slightly lower than the rear, and I've been considering lifting it about .5".
Old May 18, 2006 | 05:58 AM
  #37
ilscoobydooll
i think it may be a bushing issue i am upgrading to megan coils also and doing a clutch this weekend i will keep you guys posted on what i find.
Old May 18, 2006 | 06:25 AM
  #38
meb's Avatar
meb
Well, my Powerflex bushings are in the process of being installed. I'll let you all know...I was a little suspect about these, but it's sort of a rotational things, so perhaps not.
Old May 19, 2006 | 11:59 AM
  #39
meb's Avatar
meb
...all four ball joints replaced and the Powerflex bushings installed...did nothing for the vibration. FYI
Old Sep 2, 2006 | 10:23 AM
  #40
DOPAMINE's Avatar
DOPAMINE
yeah i have the same problem at the rpms. i think it has to do with the ride height and angle of the cv joints. i would love to hear a solution. please!!!!????
Old Sep 2, 2006 | 10:36 AM
  #41
chuckt's Avatar
chuckt
Originally Posted by RIVAL
... i would love to hear a solution. please!!!!????
The cure is new CV joints, or wait and hope for the new wear pattern to brake in. You could try and raise it back to the original height, but that may be difficult to match.
How many miles did you have on the car when you lowered it?
Old Sep 2, 2006 | 10:01 PM
  #42
DOPAMINE's Avatar
DOPAMINE
20000 miles.
Old Sep 3, 2006 | 07:08 AM
  #43
e-mini-Austin
Mini would not inspect the CV joints until I had put the stock springs back in--so I pu them back in and the vibration went away--so I left it
Old Sep 3, 2006 | 10:29 PM
  #44
pberry51mini's Avatar
pberry51mini
No Fear Gear
Originally Posted by pimpin05mini
ya i toke it to the dealer to day and they goin to replace the CV joints thats what when bad on it so ill find out if that was it or not when i get the car back
Hey, I really do get a kick out of your posts - is your spelling an issue with just typing or do the words you type appear right purely because they seem phonetically correct?
Not trying to be cruel but you singularly have outmatched the worst of any spelling bee I've ever read.
Friend, keep posting, you bring great hope for the future of our next generation.
Pablo
Old Sep 4, 2006 | 09:50 PM
  #45
J0kER's Avatar
J0kER
...O boi, hear we go again!!!
Old Sep 5, 2006 | 06:25 AM
  #46
meb's Avatar
meb
I replaced the entire axle and CV joints on the right side about 6 weeks ago. The problem is completely gone. The entire job took 1.5 hours from setup to cleanup. Getting to the bolts that hold the intermediate shaft bearing is the only hard part. curiously, the manual states that the tranny fluid must be removed. I chanced this and nothing came out when the axle was removed...but the car was jacked on the right side...
The axle and CV joints are sold as a unit - $430.00 plus a $30.00 core charge.
Old Sep 5, 2006 | 09:50 AM
  #47
jammin636's Avatar
jammin636
yikes!! thats allot if you had to do both sides.
Old Oct 1, 2006 | 06:42 PM
  #48
daemon2's Avatar
daemon2
Has anyone with this problem installed adjustable camber plates to see if the angle of the CV joint and subsequent vibration can be dialed out?
Old Oct 1, 2006 | 06:45 PM
  #49
ltz_mtr's Avatar
ltz_mtr
I have adjustables, but that didn't seem to change anything. For me going to lighter wheels/tires helped more than anything.
Old Oct 1, 2006 | 07:03 PM
  #50
daemon2's Avatar
daemon2
I put my lighter wheels on and it did make a difference. I guess I was hoping it would be gone.
