Suspension Eibach Pro Kit Installed
Old Jan 25, 2018 | 08:00 AM
F55JCW's Avatar
F55JCW
Eibach Pro Kit Installed on DDC Struts
Eibach Measures the kit at 1.2 Front and 1.2 Rear on a F56. Will post final measurements later today.
Before
After
Old Jan 25, 2018 | 08:06 AM
iwashmycar's Avatar
iwashmycar
Yes.
Old Jan 25, 2018 | 11:33 AM
WhatV8's Avatar
WhatV8
Looks great! The springs may 'relax' a bit over a couple months, so get an initial measurement and check back after a couple thousand miles to see how much more.
Old Jan 25, 2018 | 12:35 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Is the pro kit the one that comes with the sway bars too?
Old Jan 25, 2018 | 01:51 PM
F55JCW's Avatar
F55JCW
Pro Kit is just the springs.
I am going to keep an eye on the measurements and see if they settle at all over the next few thousand miles.
Old Jan 25, 2018 | 07:52 PM
vetsvette's Avatar
vetsvette
Moderator
You might want to get your alignment checked after a couple hundred miles. Looks great!
Old Jan 25, 2018 | 09:20 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
How different is the handling since the change?
Old Jan 25, 2018 | 09:37 PM
F55JCW's Avatar
F55JCW
it is marginally stiffer I think, I have only gone about 45 km's with the kit so far
Measurements from bottom of center cap to bottom of fender
Front Before
387.35 mm
Front After
358.775 mm
Lowered 28.575 mm or 1.125 Inch
Rear Before
371.475
After
346.075
Lowered 25.4 mm or 1.0 Inch
Will Measure Again in 1000 km's
Old Jan 28, 2018 | 07:24 AM
mcaanda's Avatar
mcaanda
Looks good.
Makes me think I might have to do the same.
Old Jan 31, 2018 | 12:39 PM
da3dalus's Avatar
da3dalus
Interested to see what your impressions are after a few more miles. Want to do the same setup on DDC's on my car.
kyriian
Suspension
Mar 28, 2005 05:43 PM
