Suspension Delete vibration
Old Nov 5, 2017 | 04:42 AM
Billyvall's Avatar
Billyvall
Delete vibration
How to delete the vibration in my minincooper after lowering
Old Nov 5, 2017 | 06:53 AM
UW Mitch's Avatar
UW Mitch
Did you get an alignment done?
Old Nov 5, 2017 | 07:59 AM
iwashmycar's Avatar
iwashmycar
Alignment can go a long way. Even if it aligned it can be setup differently most time....more or less caster ect.
Otherwise it may just take some time for the CVs to get comfortable with a new wear pattern, but on some cars it just never goes away. If you used coilovers you might raise it up a little
Old Nov 21, 2017 | 10:14 PM
renchjeep's Avatar
renchjeep
Delete Vibration. I almost LOL'ed. Unless you find someone making extreme-angle CV shafts for MINI's, you will most likely have vibrations. I went with H&R 1.2 lower springs, beat me to death with vibes. I kinda need to keep this 2011 for a while! Tried new CV's. Nope, still vibrated. Went to Megan springs, 1/2 drop front and 3/4 drop rears. Still vibrates. Granted, not as much, but Grrr....all alignment is to factory spec. I see the answer.....drop the engine/trans to compensate. Right? Has anyone tried that? Is it even possible? Meanwhile, vibrating down the road I go....even on part-throttle.
Old Dec 4, 2017 | 07:01 AM
Mr. Klean's Avatar
Mr. Klean
Well that sucks. That makes me not want to lower this thing...which will make me not want to keep it...which will **** me off b/c I already ordered parts for it!
Old Dec 4, 2017 | 11:15 AM
iwashmycar's Avatar
iwashmycar
They don't all, always vibrate. I still think if you get a proper lowered car alignment (forget "factory spec" since you are not such a thing anymore), then it would likely be ok. Usually springs are low, but not low enough to get vibrations. If you get it from coilovers you can adjust them as needed.
wonderboymini
Feb 25, 2017 08:01 AM
downshift1
Dec 28, 2016 03:28 PM
kevinminict
Nov 30, 2016 06:09 AM
morriskenny
Nov 18, 2016 08:55 PM
tag1260
Nov 2, 2016 12:21 PM
