Suspension Diy rear camber arms!
Old 04-28-2017, 11:59 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,715 Likes on 1,382 Posts
What about the width of the bushing? How does that compare to the stock bushing? (since it has to slot into the rear knuckle and the frame.)
  #27
Old 04-28-2017, 12:03 PM
cstrumol's Avatar
cstrumol
cstrumol is offline
Originally Posted by Scooter24
Well got the parts today and very first impression is, great! Everything seems to be solid and nothing stands out to be an issue. I went with a 17 inch center shaft. With the ends threaded Into the center shaft and measured out to the same length as the stock ones, There is 3/4 of an inch threaded Into the center shaft. I feel that is more than enough to be "safe" if you want more, then go with the 18 inch bar. But once you start getting more positive camber more will be threaded in. Overall first impression is a good one! Just have to install them and get an alignment and just drive on them and see how they last. But for 83 bucks in materials I'm willing to give it a shot. Also I went with forged steel ends that are zinc plated. You can go with polished stainless ends if you want it to look better. But since it's under the car I did not care.
Are the rod sleeves reverse threaded? So basically the parts list is :
2 rod sleeves
2 LH threaded ends
2 RH threaded ends
2 LH threaded jam nuts
2 RH threaded jam nuts
  #28
Old 04-28-2017, 12:12 PM
Scooter24's Avatar
Scooter24
Scooter24 is offline
2 rod sleeves
2 LH threaded ends
2 RH threaded ends
yeah they are reversed threaded, I just went with aluminium, you can get steel and or chromoly. But the aluminum is 6061 and should be more than strong enough.
  #29
Old 04-28-2017, 12:21 PM
Scooter24's Avatar
Scooter24
The widest part on the ends that I got (bushing with) makes the endlink 1.397 inches wide. The width of the slot in the knuckle is 1.547 inches. Little different, but not somthing crazy. I'll just have a shim made if I feel it's necessary, will see once I start installing.
  #30
Old 04-28-2017, 12:46 PM
Scooter24's Avatar
Scooter24
They is only a 15 hundredth difference between these and the mounting point. But whoever else gives these a try make sure you measure, measure, measure. I'm not sure if the stock arms are different in length on different years and models.
  #31
Old 04-28-2017, 02:14 PM
bavmotors's Avatar
bavmotors
bavmotors is offline
R53 and R56s are identical for sure.
  #32
Old 04-28-2017, 03:27 PM
randeez's Avatar
randeez
randeez is offline
damn, love the ingenuity.
are the bars hollow all the way through or just threaded on the ends?
  #33
Old 04-28-2017, 03:34 PM
Scooter24's Avatar
Scooter24
hollow all the way through and threaded at least 2 inches at the ends.
  #34
Old 05-13-2017, 12:52 PM
Scooter24's Avatar
Scooter24
Well finally got some time to install the rear lower control arms. Everything went smooth and had no issues. There is a little size difference between the ends and the stock ends but nothing a few washer couldn't fix. I Think I got 7/8 flat washers and put on both sides of the ends. Filled the gap nice and once installed everything snugged down like it should! Now just to get and alignment and see how well the last.
Attached Thumbnails Diy rear camber arms!-20170513_135109.jpg   Diy rear camber arms!-20170513_135102.jpg   Diy rear camber arms!-20170513_135636.jpg   Diy rear camber arms!-20170513_143059.jpg   Diy rear camber arms!-20170513_154014.jpg
  #35
Old 05-22-2017, 07:48 AM
cstrumol's Avatar
cstrumol
cstrumol is offline
Those look great!!! Definitely think I have to do this for my uppers to adjust the toe.
  #36
Old 05-22-2017, 09:55 AM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
ST3ALTHPSYCH0 is offline
Nice DIY!!! Cost of adjustable rear control arms is part of what prevented me from picking up a used set of lowering springs last week.
FYI, you can go all aluminum and stainless for ~$20 more.
Screen cap of cart w/ part #s included for great justice!! (Could someone w/ a vendor set of adjustable arms confirm the length of the tube?)
  #37
Old 05-25-2017, 04:10 PM
Scooter24's Avatar
Scooter24
When installing the control arms what is the torque Spec for the bolts? So far all is good I've been driving on these for a few weeks now and they are holding up great. Lock nuts are not coming loose so far so good except for a popping noise. The first week there wasn't a noise and now it's consistent when going over bumps or the car is articulating. These ends as re 5mm narrower that the stock so I filled the space with a flat washed on either side. I can get them to tighten right down and have everything tight but I'm wondering if it's to tight and it's keeping the arm from moving when the wheel goes up and down and that's where I'm getting the popping sound.? It doesn't seem like the washers would affect anything because the the stock arm has metal that is in contact with the mounting surface. But I'm also wondering if it could be that the washer as not physically attached to the end and that is moving differently then the end when the wheel moves? Hmmm
  #38
Old 05-25-2017, 04:12 PM
Scooter24's Avatar
Scooter24
Yeah, I could have went with the stainless ends but I figured since it's under the car np one would see it.
  #39
Old 05-26-2017, 03:04 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
It is possible the bushing is binding up on the washers, then letting go when you hit a bump. I would want the center Steve to be tight against the yoke, not the bushing. The washers are possibly holding the bushing tight and not letting the arm move like it wants to.
  #40
Old 05-26-2017, 07:00 AM
ST3ALTHPSYCH0
I would be more concerned about the corrosion over time rather than the looks. Chainlink fence posts are zinc plated too, after all. I'm definitely watching this thread though. I'll be doing this for adjustable rears if I ever lower my car!
  #41
Old 05-27-2017, 10:09 AM
bcriverjunky's Avatar
bcriverjunky
bcriverjunky is offline
Looks great! Might want to see if you can eliminate the washers with some longer bushing pins.
  #42
Old 05-27-2017, 10:36 AM
Scooter24's Avatar
Scooter24
yeah I'm going to pull them out and see if I can close the gap without them and if I can see if that eliminates the popping spund. If it works this will save people money if not it was a good try haha.
  #43
Old 05-27-2017, 08:52 PM
Scooter24's Avatar
Scooter24
Well I pulled the washers out and it didn't help, still had the popping sound. So I'm going to call the company and see if they have a solution or see if i can get a wider end link. If that fails, I'll make my own! This will work in the end, ha
  #44
Old 05-28-2017, 12:28 AM
bcriverjunky
Tighten up your sway bar end links for the popping sound. I don't believe that it's your arms are making that noise.
  #45
Old 05-28-2017, 12:37 AM
bcriverjunky
Here's a couple links for you to check out. http://stores.ebay.com/ASHEVILLE-MET...=p4634.c0.m322 http://autofab.com/c-335607-fabricat...and-parts.html
  #46
Old 05-28-2017, 09:49 AM
Scooter24's Avatar
Scooter24
they are tight, I put the stock arms back on and the sound is gone, so it deff was coming from the smaller end links. Either way I'm going to get this figured out so we have a cheaper option to choose from.
  #47
Old 05-31-2017, 10:40 AM
Scooter24's Avatar
Scooter24
Well I found a company in Cali that can male me a bushing to the exact size I need. The outer sleeve is quarter wall they said it would be think enough to weld a 5/8 rod to so I can thread it into my bar. But I'm wondering if that would hold over time or if the metal will get hard and be a weak point. Or I could just get a heim joint and have my friend Mill up some spacers kinda like the alta setup. Not sure what I wanna do.
  #48
Old 06-02-2017, 06:24 AM
ST3ALTHPSYCH0
Would something like this work better?
  #49
Old 06-02-2017, 08:16 AM
Scooter24's Avatar
Scooter24
I ended up getting heim joints they are precision with a Teflon lining to help with noise and smoothness. They actually had a dust cover that snaps on either side of the heim to protect it from the elements. I should be getting them today then I'm going to mill some spacers so I have the exact fit I need. Hoping to have it done this weekend bit we will see. I have quizzes and exams all next week so I need to get some studying in. Cannot wait till college is over!
  #50
Old 06-02-2017, 10:19 AM
bavmotors's Avatar
bavmotors
I don't understand why your original setup didn't work since it's exactly how most aftermarket arms are setup. Just makes me wonder if there's something being overlooked aside from the joint type.
Quick Reply: Suspension Diy rear camber arms!
