Suspension Spacer Inquery
Old Apr 13, 2016 | 09:05 PM
Casrio's Avatar
Casrio
Spacer Inquery
Just wanted to ask if running a 5mm set in front and 15mm set at the back would cause any rubbing issues with my setup. MY current setup is ST coils lowered approximately 1.5" on R112 Challenge wheels(17x7 ET 42) wrapped in 215 45 tyres.
I've searched around but did not find a definitive answer. Thanks
Old Apr 14, 2016 | 03:03 AM
cerenkov's Avatar
cerenkov
I too have R112 Challenge Wheels but with 205, 45, 17. I'm lowered about 2" with Bilstein PSS10 coilovers and 5mm spacers in the front and 15mm in the back. I don't ever have rubbing in the back but do occasionally on the front during aggressive 90 degrees cornering. If I raise the car from 2" to 1.5" lowered than I'm sure I wouldn't have any issues.
BTW, I believe that the R112 wheels are ET48
Old Apr 14, 2016 | 04:02 AM
Drivehard's Avatar
Drivehard
+1 r112 wheels are et48 9.4kg or approx 21 lbs
Pm me if interested. I have a set of 4 ecs 15 mm spacers with bolts for sale
Old Apr 14, 2016 | 08:32 PM
Casrio's Avatar
Casrio
Awesome thanks guys.
Old Apr 19, 2016 | 05:28 AM
Yep, should not be an issue with the 15mm on the r112, thats what i am running.
BucksCountyR57
Mar 1, 2018 07:21 AM
aetherair
Apr 19, 2016 02:05 PM
MAGICIAN
Apr 3, 2016 02:02 PM
Mike Isaacson
Mar 29, 2016 07:58 AM
Lmill999
Mar 25, 2016 06:11 PM
