Suspension Spacers to clear JCW brembo?
Old Jan 23, 2016 | 12:34 PM
Tweedbean's Avatar
Tweedbean
Hi need a quick bit of advice, what spacers would I need to clear f56 JCW front brakes with 18" cone spokes wheels, spec: 18x7 et54
James
Old Jan 24, 2016 | 07:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We just installed one of the F56 JCW brake kits and had to use our WMW 15mm spacers, it was a nice tight fit as anything less wouldn't have worked.
Here are the 15mm spacers we used
http://www.waymotorworks.com/15mm-wh...-f56-mini.html
Old Jan 25, 2016 | 01:15 AM
Tweedbean's Avatar
Tweedbean
Thanks did you need to change the bolts to work with these?
Old Feb 4, 2016 | 11:16 AM
MarcoPolo's Avatar
MarcoPolo
any follow up on this question?
also, did you guys replace the brake lines as well. i don't think the kit comes with brake lines. i would think if you're changing it all out, you might as well change the brake lines as well.
Old Feb 4, 2016 | 11:21 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, you'll need longer lug bolts.
888.280.7799 | 6am - 5pm PST
Old Feb 25, 2016 | 11:24 AM
Our some with the correct length bolts, but yes you will need the longer bolts based on the size : Ours come with them in the full kit
F56+ wheel spacers and bolts
https://www.northamericanmotoring.co...project-2.html
InDaClubMan
Jan 4, 2016 08:19 AM
COJCW
Dec 14, 2015 04:42 PM
MD11Driver
Tires, Wheels, & Brakes
Dec 8, 2015 12:17 PM
Hendricksen
Nov 30, 2015 10:16 AM
socalr53
Nov 29, 2015 11:09 PM
