I basically agree. Although Ryan told me before I installed them that the handling difference was so minimal that he would not be able to tell the difference on a blind test. With the 12 and 15's I'm running I would agree with him. Looks more aggressive and your car gets dirtier quicker!
I have a question for you all. I have a 2015 Cooper S that I just lowered using the new Craven Speed lowering springs. My car has the R506 18's with Pilot SS. I have too much tuck in the front and rear. I was thinking of doing a 5mm front and 10mm rear. Thoughts??
After delivery & time to study the car, I noticed the wheels are inboard significantly to the body.
Its bad enough Mini outfits even their so-called "hot rod" with little dinky skinny *** wheels & tires.
So i ordered 15 mm rear spacers & 6 mm front spacers from OutMotoring to kind of toughen up the whimpy Mini wheel look.
Looks much better now. Next spring 18x8 Team Dynamics wheels with 235-35-18 rubber get mounted.
One of the best looking MINI's on this forum! (or any for that matter!)
If I mod my JCW you can bet I'll go similar to this....and definitely go with the 235/35/18 tires, as that diameter matches stock! Wide tires make the car look so much better imo...love the F56 but those 205 tires are indeed wimpy!
+1 most are doing the smaller in the front and ~15 in the rear just on stock ride height.
i just installed 15mm all around on my cooper s. i should be doing the drop this weekend with NM springs. the rear is perfect, the front is a little wide. I will see how it looks after the drop. If it is still too wide, i will get some smaller spacers for the front. I have 215's also...
Forgive me if I sound like a noob because I really know nothing about aftermarket products and coming from an R56, I thought it didn't need to be pushed out. Now that I got my F56 JCW, the wheels aren't flushed enough to my liking. Is there a reason you went 6/15 instead of making it 15/15? The front wheels do seem to jut out more compared to the rear. I've even read this one guy put 20/20 and I'm not sure if that's an overkill. Does it just depend on what you want it to look like?
Also, whatever size I choose, would a wheel swap effect how much it juts out? I'm going to switch to a winter set once it it gets cold would those spacers effect it? I guess what I'm asking is what's the safest route to go.
I have 18 X 8 wheels. The rear seems to have more of a tuck than the front. I have a 4 door so not sure if there's a difference with 2 doors. I am considering 18x8.5 for rears if I ever get another set of wheels.
