Suspension still have some shake / shimmy at "high speed"
Old Oct 8, 2014 | 09:37 AM
astroBlackMetallic_Mini's Avatar
had an alignment after my accident, got new LCA bushings (powerflex) and had the tires balanced.
this fixed my shimmy at normal speeds, but i still have some tiny wheel shake above 70, and gets way more noticeable at like 90.
only thing left i can think of is the steering column cracking, causing the shimmy...
can anyone think of anything else?
asked the mechanic to replace the tie rod ends (since i had them, and he was in there) but he said "they looked fine" and did not do it
beginning to wonder now...
Old Oct 8, 2014 | 09:56 AM
v10climber's Avatar
v10climber
Get the tires rebalanced.
Sent from my DROID RAZR HD using NAMotoring
Old Oct 8, 2014 | 09:57 AM
they were just balanced like a couple of weeks ago; still had a bit of shake at high speeds...
cant be the tires.
Old Oct 8, 2014 | 10:05 AM
v10climber's Avatar
v10climber
cant be the tires.
I realize you already had them balanced but I would take them back and tell then you still have a vibration. Get them balanced again. Its not unusual for them to not get it 100% right the first time depending on the machine they're using.
An even better test would be to find someone willing to swap wheels with you for a bit to isolate the wheels/tires as either an issue or not.
Old Oct 8, 2014 | 10:15 AM
JABowders's Avatar
JABowders
Veteran: Army
...also have the wheels checked for being true... You may have have bent a wheel in the accident and are unaware of it.
Motor on!
Old Oct 8, 2014 | 10:28 AM
edgy's Avatar
edgy
Same problem - rebalancing fixed. I was 7 oz of weight off - I may have to rethink using a power washer on my wheels. I'm sure this played a part in my balance issues.
Filmy
15
Jun 6, 2023 06:27 AM
gpwpat
Sep 15, 2015 11:58 AM
gzaos
Sep 14, 2015 04:21 AM
Sep 3, 2015 10:29 AM
