Suspension rear sway bar
Old May 14, 2014 | 04:48 AM
larmini's Avatar
larmini
rear sway bar
Going to install one. What are you guys running and was it easy install. I have 2013 clubman s.
Old May 14, 2014 | 05:37 AM
danjreed's Avatar
danjreed
I installed the H-Sport Comp bar in my 2013 Clubman S. Love it.
Not too bad to install. I found I had to fully disconnect the rear subframe to fit the new big-fat bar in.. Marked the mounting points with paint before removal. Needed a e14 (torx) socket to take down the bolts on the subframe. Everything else was hand tools.
Remove rear wheels.
Unclip sensor wires from Strut bodies.
Remove dust shields over lower bolts on shocks.
Unbolt rear sway links/
Remove rear shocks/springs (3 bolts).
Drop subframe (use a jack to support it).
Remove rear bar brackets on subframe.
Remove bar.
Grease the hell out of the new sway bushings.
Install new bar/brackets (new brackets are FAT).
Put it all back together.
Took two hours (yes I clocked it).
No need to remove heat shields or exhaust.
I have the bar on the middle setting, its a HUGE difference. Really makes the car a lot more fun to drive. Very neutral. Throttle steer on corners at will!
Old May 14, 2014 | 06:49 AM
Fly'n Brick's Avatar
Fly'n Brick
+1
And before you ask:
Cut a 2X4 to fit between the front and rear jack points, shove it clear up against the rocker seam, set the jack at mid point and lift each side to set floor stands at the rear jack points. DO NOT work on it using only jacks.
Old May 14, 2014 | 07:17 AM
larmini's Avatar
larmini
Thanks for the write up.
Old May 14, 2014 | 07:18 AM
larmini's Avatar
larmini
What's up with the mini madness one 22mm
Old May 14, 2014 | 07:36 AM
minibx's Avatar
minibx
. Very easy to do, I installed a 19mm H&R very happy with it
Old May 14, 2014 | 07:41 AM
Z06_Pilot's Avatar
Z06_Pilot
I have the Hotchkis Competition 25mm hollow, rear ASB on my R56 JCW, set on the middle hole, and really like it. Stiff, but not too harsh. but then, I don't drive any of my vehicles for comfort-it's handling above all else.
Had my dealer install it as I am not set up to lift my car at home.
Old May 14, 2014 | 07:44 AM
LTLMCPE's Avatar
LTLMCPE
A third recommendation on the H Sport Comp rear bar from me. Got mine from Way.
Old May 14, 2014 | 08:08 AM
Z06_Pilot's Avatar
Z06_Pilot
Forgot to mention, I got mine from Aaron at Outmotoring, where I buy all my stuff.
Old May 14, 2014 | 09:30 AM
mbwicz's Avatar
mbwicz
Another vote for the 1" Hotchkis tubular bar (oops, I mean 25.5mm). When I did it, I was able to leave one side of the subframe bolted in (only by a few threads), so that way it was pretty easy to get back in place.
Be aware when you are reinstalling the lower shock bolts that these can strip out. The published torque value is really high on these.
Have fun,
Mike
Old May 15, 2014 | 03:50 PM
larmini's Avatar
larmini
Can the sub frame fall down with the 4 bolts removed
Old May 15, 2014 | 03:55 PM
minibx's Avatar
minibx
Nope
Old May 15, 2014 | 04:06 PM
larmini's Avatar
larmini
Ok cool. I want to do it on a lift
Old May 15, 2014 | 04:10 PM
minibx's Avatar
minibx
Everything is easier on a lift if you have access to one that's always a plus, for this job, is not critical but like I said it will make it easier. :-) good luck
Old May 15, 2014 | 04:12 PM
larmini's Avatar
larmini
It's seems pretty straight forward. Hope so.
Old May 15, 2014 | 04:31 PM
danjreed's Avatar
danjreed
I did use a pencil jack... Make sure you don't stretch the parking brake cables, brake lines, etc...
I also used a lift. Very easy that way..
Old May 15, 2014 | 04:38 PM
larmini's Avatar
larmini
Seems like it should take about hour or so with a lift.
Old May 16, 2014 | 06:11 PM
danjreed's Avatar
danjreed
Wow - the book time is THREE hours!
Whhhhaaat?!
LOL.
I could drink 3 beers and still make it under that time!
Old May 16, 2014 | 06:12 PM
larmini's Avatar
larmini
I looked it up on ccc auto and it's 1.1 hr seems a little better
Old May 16, 2014 | 06:57 PM
danjreed's Avatar
danjreed
I looked mine with with Mitchell One.
They spec dropping the entire subframe.. which I guess adds to the time..
Old May 17, 2014 | 04:47 AM
larmini's Avatar
larmini
That's probably more like it. But I figure just a couple. I'll let you guys know what happens.
Old May 20, 2014 | 09:12 AM
afadeev's Avatar
afadeev
Originally Posted by danjreed
Originally Posted by [B
larmini][/B]
You don't really drop the sub-frame, just remove 4 (IIRC) bolts and allow it to drop a few inches to buy more space to maneuver the sway bar in/out.
Extra 15 minutes, at most.
a
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
