Suspension R/S axle replacement
Old Dec 9, 2013 | 01:25 PM
98oilhead's Avatar
98oilhead
Read the Bentley repair manual about how to do this job, which, from my expierence from many years ago, seems more complicated than necessary. I have, in the past, on other front wheel drive cars been able to replace axles by removing the tie rod end so that the turning the wheel gave enough clearance to remove the shaft. Any thoughts from the inmates?
Old Dec 9, 2013 | 01:55 PM
xsmini's Avatar
xsmini
What else is the Bentley saying? I've done a couple, and don't really remember too many steps.
Axle nut
Carrier bearing bolts (probably has an official name)
lower ball joint
yank out
It's been awhile, but I can't think of anything else.
Nik
Old Dec 10, 2013 | 04:35 AM
98oilhead's Avatar
98oilhead
They basically suggest undoing..bottom ball joint, tie rod end and a couple of other things...seems like over doing it.
Thanks for your reply.
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
RHcoopers
Aug 6, 2015 07:33 AM
