Suspension JCW Suspension - All Fine threads must be replaced
Old Jan 14, 2013 | 06:59 PM
k_h_d's Avatar
k_h_d
The JCW suspension came with mutiple different replacement nuts. In the factory instructions it states that "All Fine threads must be replaced".
The only nuts I know that I replaced were the to locking nuts that hold the rear springs / struts together. The ones that go on top of the rear spring perch.
Is it absolutely necessary to go and replace some of the bolts that I had to take apart/back together with the new ones? I torqued all the real major ones to spec. The bolts on the swaybars were just torqued as tight as I could get them because they had to be tightened with both the 5mm allen and a wrench.
Lastly, how are the nuts on the top of the front and rear perches suppose to be tightened? I used my electric impact wrench...
Old Jan 14, 2013 | 07:21 PM
Eddie07S's Avatar
Eddie07S
Ouch...other threads say that you can snap the shock stem using an impact wrench to tighten that nut. Hope yours is OK.
When I change my shocks, I used an allen wrench and a 13/16 socket and just tightened them the best I could. Never had a problem. This included track days and autoXs.
There is a really good DIY thread for this:
https://www.northamericanmotoring.co...ll-how-to.html
Old Jan 15, 2013 | 05:03 PM
k_h_d's Avatar
k_h_d
Thanks for the heads up in the future. They tightened up just fine. Its an electric impact wrench so its not going to get as tight as a really high capacity air driven one. Other writeups (one from Alta that I used), said to use the impact wrench.
Old Jan 16, 2013 | 09:15 PM
Phobix's Avatar
Phobix
impact on a low setting, no more than 50 lbs, is fine.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
