Suspension help
Old Jan 12, 2013 | 10:22 AM
crazydrumer911's Avatar
crazydrumer911
help
Just installed my d2 rs coilovers on my 05 McDonald and im getting a slighht clunking noise in the front I have adjustable swabar endlinks in the front as well j think that is rubbing on my frame can someone help thanxs
Old Jan 24, 2013 | 09:01 AM
Instanced's Avatar
Instanced
Stop DD'n your mini and start DD'n one of your "GTR's" or how about your R8???hehehehehehehehehe
Also... learn to type/text/spell.
To help you: get down under there and fix it yourself... no one here is going to come to your mansion and do it for you... or you can take it to your mechanic. if ish is rubbing, look for signs of rubbing down there and make the necessary adjustments. perhaps those adjustable endlinks aren't going to work with those coil overs... however I don't see any reason why they would have a problem.... ...
Old Jan 24, 2013 | 01:13 PM
quikmni's Avatar
quikmni
It could be one of many possible problems.
- Strut rubbing on the drivers side inner wheel well where there is a bump in the sheetmetal. You might need to pound the bump down a little for clearanve.
- Top strut nut not threaded all the way down, allowing the spring to move around a little. Compare exposed threads on both sides to see if one has less threads exposed indicating that the nut is not threaded down as far.
- Loose end link. Check to make sure nuts are tight.
Old Jan 24, 2013 | 01:55 PM
Braminator's Avatar
Braminator
Gibberish. How about english. Bahahahaha
